Question about ATI RADEON X600 Pro, (128 MB) PCI Express Graphic Card
ZD8000 Hi-I downloaded and tried your solution but I need help. 1.  The Modder failed the 3 checks and I downloaded the mxml.6 and still failed. 2. When I mod a driver and then do to mod the memory size I can not find the driver I moded???? 3.  Help Thanks, Toni
Help
Posted on Aug 09, 2008
Hi i have a dt125r fitted with a 3mb engine and a 3rm9 wireing loom, no lights on the bike as its not for the road, the loom is complete missing only the neutral relay, im not geting a spark and ive tried...
Hi, Markhowarth8 and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
Yamaha Motorcycle Parts Spares From Europes Number 1 MSP
http://www.dt125.cz/download/Owners_Manual-DT125X_RE.pdf
Yamaha DT 125 2000
http://www.dirtntrial.com/tuning.htm
Apr 28, 2011 | 2003 Yamaha DT 125 R
Where exactly is the builtin microphone on HP zd8000 laptop, if thr is ?
Download the pdf file from the bellow link and install any adobe reader,
For adobe reader download from http://filehippo.com/download_adobe_reader/
Follow the bellow link,
http://h10032.www1.hp.com/ctg/Manual/c01383095.pdfl
Hope this helps.
Feb 25, 2011 | HP Pavilion zd8000 Notebook
Replacing power jack on HP-zd8000
Ofcourse you to disassemble it and have only the main board and then underneath it is that connection of that jack, so things you need are,
1- Soldering iron and soldering wire
2- Screw drivers
3- Multimeter
4- the spare jack
5- Love / Care for you laptop, so that you dont mess it up.
Cheers
Sep 11, 2009 | HP Pavilion zd8000 Notebook
I upgrade my sony vaio pcg-k35 to vista but the screen does not fit the screen what graphic or video driver do i use pls.. help me with my problem.. ihave downloaded all the drivers for vista compatability...
go to the following website, scroll down and download mobility modder. http://www.driverheaven.net/modtool.php you will also need to download the lates catalyst software from ati don't worry that it isn't for your graphics card because mobility modder will change the files. finally follow all the instructions on the dh modder webpage where you downloaded it from and you can't go wrong. i used to have a sony vaio and i couldn't beleive how sony supports their customers after sale. they haven't and probably never will release a driver for these graphics cards. Shame on Sony!
Apr 04, 2009 | Sony VAIO PCG-K35 Notebook
Lightsccribe not functioning
download and install nero it comes with lightscribe and installs lightscribe drivers as part of package (nero 6)
Jan 16, 2009 | HP Pavilion zd8000 Notebook
HP pavilion zd8000 start-up problem.
Try to unplug all the PCI cards and boot, if its still doing it check the ram. If its still doing it check to see if the power supply is good. If all that fails, It could be eather a bad mother board or bad processor.
Oct 03, 2008 | HP Pavilion zd8000 Notebook
ABS Light gives out three codes,Where can I get a list of codes to trouble shoot by?
Most Honda ABS warning light will blink in 2 parts, main system and then sub system to form the code pair. As an example is 3 blinks then 3 blinks is a code 3-5. Once determined, reference below listing.
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Honda Accord Cars & Trucks
OUT OF PAPER
1.Try downloading firmware
2.Check for driver
3.Check for LED indications on printer front panel.
4. Try removing dust between fork sensors situated below card feeder.
5. Try removing dust below ribbon sensor plate (blue led ) .
6.Do self adjustment
Hope this helps
Mar 15, 2008 | Evolis Dualys Thermal Card Printer
ATI Mobility Radeon X600 (PCI Express?), in an HP Pavilion zd8000 Notebook.
The Deadlock Bug Finally Solved
I had the same problem for a year or so. I used vista in the meanwhile, but after a 3D bug I got upset and decided to try fix this bug, finally succeded in it. I'm sure it has something to do with the memory, but still there's a mistery........
The solution :
It can be a little wierd, the softwares i used are : ASO - Advanced System Optimizer 2.2 and Mobility Modder 1.0 Final.
Step 1 (ASO) : In the windows optimizer at the
System Performance #2 I turned on the :
Improve Core Kernael Performance
Enable Large System Cache
(I made the cache size 1,024 - not sure if this was necessary)
Theese options were to force the system to write the swap on memory instead of your HDD
Step 2 (Mobility modder) : First download a new Catalist Driver from anywhere on the net, then the modder from :
http://www.techpowerup.com/downloads/1052/Mobility_Modder_1.0_Final.html
This software is quite handy because you can use the latest catalyst on your mobility radeon.
After The modding I've set the Graphics memory on 128MB -from (it was 256 earlier) -
The only thing left for you now is to install the newly modded catalyst and enyoy the advancements of your 3D card again.
PS
Not sure if step 1 is necessary, but my problem was solved after step 2, so my 3D card was back form the DeadLock and Infinite loops, and finally running smoothly on XP again.
Btw I have a HP zd8000 with x600 mobility.
Dec 07, 2007 | ATI RADEON X600 Pro, (128 MB) PCI Express...
ATI RADEON X600 Pro, (128 MB) PCI Express Graphic Card Logo
59 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
