When i connect my pc to the pc input on the tv i cant seem to find the channel
Plus i have lost remote
  • solo21 Feb 14, 2009
    get "unsupported video signal" when I hook up my laptop to the tv? it shows the initial boot up, but then when I get to my log in screen the tv changes to this message.
  • Anonymous Feb 21, 2009
    Connect PC VGA Connection to Toshiba REGZA 47HL167 TV
  • 5,568 Answers
You put too much text in the subject line so your primary problem is not seen.
You need to reply and state the trouble in the text box, not the subject line.
You also need to give brand and model number when asking for help; we are not magicians.
Once you can find those items, check with:
http://remotes.com/
Posted on Jun 17, 2008
My grandma has recently been gifted a Polaroid TV as a Christmas gift. When the free view channels had the TV reset she lost the signal to an outdoor cctv camera for the building. We can't seem to get it...
probably the camera is either analogue or video . How was it connected to the TV via the Aerial Cable or via an AV input
If the camera is Analogue it may be on a ATV channel. So you would need to switch the input Source on the remote for the tv and check the ATV channels. If it was on a AV then try checking the AV input sources.
The free view channels is probably DTV source . .
Jan 23, 2015 | Televison & Video
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
I have connected my ps one to the television but cant seem to find the channel the visual is one or tune it in please help
  • If you using standard AV cables, (Yellow,White and Red) make sure they are connected to the correct INPUTS in the back of your TV. Now you should be able to switch to VIDEO or INPUT on your TV. Usually there is an INPUT or VIDEO SOURCE button on the remote, or an INPUT or MENU button on the front of the TV.
  • If you are using an RF Adapter, it's a simple matter of connecting it to the CABLE connection in the rear of your TV. Turn on the PS1 and surf to either channel 3 or 4 on the TV you should have a signal now.
Hope this helps, please rate.
Jeremy
Jun 20, 2010 | Video Game Consoles & Games
Cant use scart socket
Press the "TV/AV/PC" button to display the choice of input sources, move to the required choice (SCART in your case) using the channel up/down buttons, then press the volume + or - button to selectyour choice.
Feb 18, 2010 | Televison & Video
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
External input
I'm not overly familiar with your brand, but generally there are 2 ways to get to the AV input.
1) Use the TV/Video button on the remote (if there is one)
2) Channel up or down from the last channel at the high or low end. In other words: channel down from channel 2 may bring you to the AV input.
Hope this helps,
Dan
Sep 23, 2008 | Orion Televison & Video
Input
Use a RF Modulator. This will allow you to connect the dvd to the antenna jack of the tv.
Sep 01, 2008 | Televison & Video
Unable to get cable channel programmed into set
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Apr 23, 2008 | Mitsubishi WS-55807 TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
Televison & Video Logo
535 people viewed this question
Top Televison & Video Experts
Electro Med Services...
