Question about NetGear RangeMax WPN824 Router
I am having a problem with a netgear wireless router (WPN824v2), and getting no help from them as the product is refurbished. It is kicking offline, and interfering with my phone (Clear Choice phone service, not typical phone line). I have moved the phone, even though the frequency is different (the phone runs on DECT 6.0). I have spoken with my isp (Clear Wireless), and according to them, the router is configured as it should be. I am just wondering if there is a kink with the router, or if perhaps I have some settings incorrect within the network (private, password protected) I set up on my desktop (Vista) for my laptop (Mac). Any help, suggestions, or advice would be greatly appreciated, as this kick off is happening about every 5-10 minutes. It is making it impossible to be on the phone, or online.
  • NetGear Master
  • 7,733 Answers
Improving Wireless Range: Tuning Equipment
Using the best channels has a big effect on network performance. Your goal is to choose settings that avoid interference from other networking and radio frequency equipment. (If you have 802.11a or 802.11a/g, channel selection is less important, skip to "Reducing Wireless Network Traffic".)
To see all your options start with: Improving Wireless Range: Overview
If you have a simple home network, and aren't close to neighbors with wireless equipment, you may be lucky enough just to choose between many channels that work well.
Complications arise when:
  • You want much better coverage than you're getting.
  • You use multiple access points or wireless routers. (Then you'll probably be using more than one channel.)
  • You aren't the only person nearby running a wireless network.
Simple Spacing of Channels
As explained in Improving Wireless Range: Overview, improving signal strength is not like adding more lights to get a brighter livingroom. Devices that transmit powerfully - such as routers, access points, and cell phone base stations - confuse one another. It's necessary to distance them and to have them use different channels.
For 802.11b and 802.11g, there are 11 channels for wireless equipment (13 channels in Europe). In the simple situation where there's little interference, you can choose any channel that works for you. When there is interference from wireless networks that overlap with one another, each network should use one of the non-overlapping channels: 1, 6, or 11 (1, 7, 13 in Europe). Then, 3 networks can use the same space with minimum interference. If you can't do that, choose channels as widely spaces as possible.
You can use a combination of access points and antennas and other equipment to create local "spotlights" of strong transmission, rather than trying to cover everywhere.
What If a Channel I Want to Use Has Too Much Noise (Interference)?
If your neighbor has a wireless network, it wouldn't be surprising that they are already using channel 1 and channel 11. Unfortunately, you can't completely avoid interference just by using other channels. Wireless protocols 802.11b and 11g only have 3 non-overlapping channels. Therefore when 4 or more channels are used in the same area, the level of interference can increase notably. If you and your close neighbor both have a router and a wireless access point, for example - which makes a total of four powerful transmitters - both of you will have a certain amount of interference.
If there's a severe problem, a practical and sociable thing is to talk to your neighbors using wireless networks that can be seen when you scan. Together, you can choose optimal channels for your respective networks. You'll want your own channels at least 5 apart. So, for example, you could use channels 1 and 8, and your neighbor could use 5 and 11.
You may be able to place routers and access points further away inside your homes. After all, the kinds of physical barriers that reduce your transmission range also reduce the signal that your neighbor doesn't want to see.
Super G technology is faster, but it uses two, non-configurable channels. Therefore it may not be possible to pick other channels that avoid its interference.
If you can use a directional antenna, or an antenna cable to shift an antenna, that can help you both. See the articles on antenna selection.
When there's noise, your network performance drops, so one approach is not to stop the noise, but to reduce the amount of network data being transmitted.
In a noisy environment, it may be useful to keep part of your network wired. If Ethernet cabling isn't an option, consider NETGEAR's Powerline products - using existing home wiring instead of cables.
When SSID Broadcast is turned on, it's easiest for equipment to find the strongest signal. However this also causes network overhead. When the SSID is broadcast, your neighbor's equipment may keep a record of it, and automatically try to connect several times a second; this can cause significant performance reduction. So where there are close networks, turn off SSID Broadcast, and change the default SSID.
Turning off WEP and WPA may increase network throughput, but exposes your network to hackers. This is not recommended, except for testing purposes.
Posted on Nov 09, 2010
I have a netgear WPN824v2 wireless router. I have just bought an iphone 4 and although I can get onto the wireless network, I can't see the interenet. Any thoughts appreciated
Some things to try:
1) Check the current version of firmware on your WPN824v2. If it is older than version 2.0.26, then try downloading and installing the firmware update to see if this resolves the issue.
Firmware Update: (click here) [Note: directions for performing the update are on this page as well]
2) Check whether disabling IPv6 on both laptops makes any difference. If you need help doing this, please ask me in a reply.
3) Verify that both laptops are using automatic (DHCP) IP address assignment
4) Verify that MAC address filtering is not preventing the second laptop.
Again, if you have any questions about how to do any of these checks, please feel free to send a reply. Also if after we're done with this session and you are happy with the information provided, please consider rating it with 3 or 4 thumbs-up.
Thanks for using FixYa and Happy New Year!
Jan 02, 2011 | NetGear RangeMax WPN824 Router
I have a netbook running Windows CE 6.0 and I cannot get it to connect to my Netgear wireless router WPN824v2....
The Netgear wireless router needs the wireless settings configured and then the wireless card in the netbook needs to be configured with the wireless router's settings so it can communicate with the wireless router.
For instructions on setting up and securing your wireless network - please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 21, 2009 | Computers & Internet
Netbook Windows ce 6.0 cannot connect to Netgear wireless route
To connect to the Netgear wireless router the Netgear wireless needs to be configured and the wireless card in the netbook needs to be configured with the Netgear's wireless settings.
To configure both the Netgear and the wireless card in the netbook, please follow my instructions - please click on this link :-
Dec 19, 2009 | Computers & Internet
Cant get the net work key for wpn824v2
Its the wep number on the back of the router, type that in and you are connected!
Nov 27, 2009 | NetGear RangeMax WPN824 Wireless Router...
Lost software to make the router work; have netgear WPN 824 v2; and a packerd bell computer with windows xp
Netgear Support and the support page for the WPN824v2 wireless router,
http://kb.netgear.com/app/products/model/a_id/2629
Click on the ->Downloads tab.
Now click on -> WPN824v2 Firmware Version 2.0.26, that is in blue.
On the next page right-click on -> Right-click and Save to Download (In the orange 'button'. Click on the button that matches where you are.
1.North America?
Or
2.World Wide Version)
Now in the drop down menu that appears after you right-click on the appropriate button, look down this list, and click on ->Save link as
A medium size window will come up. (Save As)
At the top of this window you will see -> Save in:, and a box to the right of it. See if in that box it states -> Desktop
If it does Not, go to the right of the box, and Left-click on the down arrow. This will open a file tree. Look in the file tree for -> Desktop, and click on it.
Now go below and click on -> Save.
You will see a download progress bar. After the file has finished downloading, close all windows, and go back to your desktop screen.
There is the file. Now double-click on it. Follow the instructions.
Sep 01, 2009 | NetGear RangeMax WPN824 Wireless Router...
How can i connect my ipod touch to the netgear maxrange router wpn824v2
Follow the steps below to configure settings:
1. Open a browser on a computer connected to the router.
2. Access the router using http://www.routerlogin.com or http://192.168.1.1
3. Username is admin and password is password
4. Click on Wireless settings in the left hand side menu.
5. Under security option select WEP and in key1 type 9876543210 click Apply.
Scan for the wireless network on the Itouch and connect to the network using the password as set above.
Rate it, if it helps.
Anand
Jul 12, 2009 | NetGear RangeMax WPN824 Router
Netgear wpn824v2
Plug your modem into the Internet port on the router, plug in any computers that will be hard wired. Open Internet Explorer and type http://192.168.1.1 This will start up the Netgear install wizard.
May 22, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax WPN824 Router Logo
194 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
