Question about HP PSC 1350 All-In-One Thermal Printer
My 1350 printer says it is out of paper and I have already added paper, but it doesn't recognize that.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
How do I load paper into my Canon Pixma MX452 printer?
A lot of times the printer has a small piece of paper jammed in it or has had a jam and will not recognize the new paper. Try this to see if it resolves your issue. http://www.wikihow.com/Clear-a-Paper-Jam
Jun 25, 2014 | Canon Pixma MX452
1350 toshiba copier copy gets stuck
You need to clean the feed rollers for all your trays and for your document feeder or adf. If that doesn't work then replace them. But before you do that try checking if there is any paper, ripped or otherwise blocking paper path and removie it. It may just be that simple.
TOSHIBA BD 1350 SUPPLIES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Sep 12, 2012 | Toshiba T1350 T-1350 Compatible Copier...
My printer (HP PSC 1350) says there is a paper jam but I have taken the paper out, taken the back off and there is no paper jam. Is there a way to reset it or something?
hi
unplug the printer from power source
open the upper cover
move the CR cartridge carfully at the right position look inside is there any broken pices
Oct 27, 2010 | HP PSC 1350 All-In-One Thermal Printer
I sent the job to print and it looks like it's printing but no ink on paper I already change the ink .
plz try by reloading the drivers, if the problem is not solved then check the paper size in the printer is correct
Nov 06, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 20, 2009 | HP Photosmart 7450 InkJet Printer
HP 1350 all-in-one ran out of paper.
Every time this device runs out of paper, it's a hassle. I powered off the pc and the printer, and then moved the usb cable to another usb port. Power on the printer and after it has gone thru its startup, power on the computer. Then the jobs in the queue printed just fine.
Apr 14, 2009 | HP PSC 1350 All-In-One Thermal Printer
Canon ip3600: New Printer doesn t recognize that
Possible solution:
In Preferences/Properties, make sure that "Automatically Select" is selected in "Paper Source"
Mar 31, 2009 | Canon PIXMA iP3600 Photo Printer
Scan Editable Documents to Microsoft Word 2007
Hi - off the top of my head, without going in to check the settings at the moment, I would say to go to your PRINTERS & FAXES folder (Start/control panel/Printers & Faxes), and make sure that the printer you want things to go to is set as your DEFAULT printer.
We have the Home & Student edition as well, and it has different defaults - it took me a couple of tries to print to realize that it was trying to send things to a printer/program that really didn't even exist! When we installed MS Office HSE07, it did a lot of tweaking to our system without permission or our knowledge! Shame on MS! It added a printer that we didn't even have, and changed the default to that new odd printer!
Also, for a scanned file, you can set your computer to automatically recognize scanned files as a certain type. Did you want to do that? I hesitate to say set it to have all scanned items sent directly to the printer, since you might scan things you do not need to print!
I don't have my 1350 hooked up at the moment, or I'd jump in and find the exact settings for you (we also run XP). But, it really sounds like the installation of the MS Office has tweaked your printer default settings.
Check that first, and see if that will solve the problem...
Dec 25, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350
Try cleaning your printer and its rubber rollers. Also make sure there is no object stuck inside the printer that prevents the printer from loading the paper smoothly. may be you have no other problem.
Oct 24, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
54 people viewed this question
Clive
Clive
