Question about KLH ASW10-125C Subwoofer
I have a KLH ASW10-125C Subwoofer and a Harman Kardon AVR 3600 receiver. What should the setting be for volume, phase and crossover frequency?
  • 3 Answers
Home Theater
volume - personal taste - usually just high enough that you notice the bass - try turning down until you don't notice it then turn up one notch in the switch
phase - depends on distance from other speakers - try initially setting to 0 degrees
cross-over frequency - depends on your other speakers - try setting at 60-100Hz
Posted on Nov 16, 2010
Harman kardon avr 3600 no signal after firmware update..i think the firmware only got partial install
Try resetting the processor follow the link this will tell you how to do it.
https://www.manualslib.com/manual/278933/Harman-Kardon-Avr-300.html?page=38
Nov 06, 2016 | Harman Kardon Audio Players & Recorders
My subwoofer will not wake up, regardless of whether I flip the switch from Auto to On or not. Suggestions?
The sub settings for testing should be: Crossover frequency - Max; Volume - Mid; Phase - Normal.
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay or not.
If you've got power then that's a good thing. It could be something simple as a broken solder joint or bulging capacitor.
Aug 05, 2014 | Harman Kardon HKTS 14 System
Protect mode
thank you for the advise. i have the harmon kardon avr 3600 and was worried that i destroyed it. i will take it to a shop and get it fixed since it is a great receiver.
Jan 25, 2013 | Harman Kardon AVR 3600
I'm about to hook up my KLH to an Onkyo Receiver with Audyssey sound features. 2 questions: it asks me to set my sub to 75 DB. Since my volume dial goes 0-10, which number maps to 75 DB? Also, what...
I think it wants you to raise the volume high enough on the sub so IT can hear at least 75dB. It can always adjust the sub downward if necessary. Max it out at the sub and let Audyssey deal with the adjustment.
Your crossover frequency selection would be a piont below which you want the sub to activate. It depends on the bass capabilities of your other speakers. You want some overlap so there's no droop in the crossover region where your main speakers roll off.
Jul 13, 2011 | KLH ASW10-120 Subwoofer
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I have a Harman Kardon receiver Type AVR 500 RDS. Can I set it to 5ohz or 60 hz as I wish?
Should only set to frequency of your power supply otherwise may damage your receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
How do you hook up a powered sub to Harman Kardon AVR 240 Receiver
On the rear, at the bottom left you have the Pre Out connectors - in there the Subwoofer is clearly labeled : use it.
Apr 22, 2011 | Harman Kardon AVR 240 Receiver
My receiver doesn't have a dedicated subwoofer output, can I still hook up a subwoofer? I have a harmon kardon avr 25
That would depend mostly on your subwoofer. There are some that slave off the front left and right speaker outputs and still pass the amp's power to the Front Speakers. That would be the only way that would ensure volume control.
Otherwise you have to feed a self-powered sub from the Tape Outs but that won't allow volume control from the H-K.
May 29, 2010 | Harman Kardon AVR 25 MKII
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
Subwoofer
set your front left and right speakers to small
Mar 28, 2007 | Denon AVR-3806 Receiver
KLH ASW10-125C Subwoofer Logo
292 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
