When I try to set the date and time on my computer to the correct one, it shuts down (gets a blue screen) and I have to reboot. Why is this happening and how can I fix it?
  • 4,281 Answers
So many computer face this blue screen fetal errors on windows.This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.Also this error comes when there is bed indexing unit in hard drive.You can solve this errors with following 2 methods.(1)When you power up the computer press F8 key then enter in safe mode.Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.Boot your computer with that diskFor that when you power up the computer press F1 or F2 "del" key to enter in bios.Then go to boot menu and set first boot device as your cd or dvd rom.Then save settings and exit bios.Insert windows disk in cd /dvd rom.Then it boot with that disk.Then you get this message "Press any key to boot from cd.."Then press any key.Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"Then type "y"Then it fix error on hard drive.Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.Thanks for using FixYa.
Posted on Nov 09, 2010
Date and Time resets every time I shut down my desktop PC.
you know how to get into bios so set the time and when you press esc to move on it will ask for a save settings Y/N change the N to Y and then esc
Sep 10, 2016 | Computers & Internet
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
How to reset to factory default with out discs
Asus has become one of the "Top 5" computer manufacturers worldwide.
CNET attributes this growth to the Netbook craze.
The company's name comes from the last four letters of "Pegasus," the winged horse from Greek Mythology.
You can restore your Asus laptop to the original factory settings in about five minutes.
Restart your ASUS laptop and press the "F9" key while the computer is booting up.
This will open the boot screen. Select "Recover Windows to Entire HD" and press "Enter."
Press "Y" three times when asked if you are sure that you want to restore.
The laptop will restore the factory settings.
The computer will then shut down and start up again.
Approve the license agreement, then select your "Language preference."
Enter your name into the box and click "Next."
Enter your password twice on the next screen and select "Next."
Enter the time zone and date information, then select "Next." Select "Finish" on the next screen and the computer will reboot.
hope this helps
Oct 16, 2012 | ASUS NOTEBOOKS G53JW3DE CI7173 156 6GB...
Laptop date and time setting get disturbed automatically when i reboot my laptop
When you boot up and the Date & Time is wrong then you correct the Date & Time, then when you shut down and boot up again the Date and Time has changed. This is an indication that the BIOS battery is flat and you need to replace the BIOS battery. Install a new BIOS battery, go into the BIOS setting and set the Date & Time etc. and the new battery will keep your settings stored in the BIOS.
Feb 09, 2012 | Dell Inspiron 1464 Notebook
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Not sure if the rtc error is the cause of my problem. Laptop will not boot up after it has been shut down for a few hours. It will turn on and get past the acer screen then simply sits there and does...
You are right on your first assumption...the RTC battery is dead and keeps resetting the cmos control settings. The operating system however is updated to the present and that is where things don't want to play nice together. Change the battery, boot the laptop in safe mode with networking, adjust the date and time. When the laptop loads and is stable, then try to reboot normally into windows.
Below is the link to the service manual for that laptop, you can either click on or copy and paste into the browser address bar. It is free to use, copy and print.
http://tim.id.au/laptops/acer/aspire%205050%203050.pdf
Jun 28, 2010 | Acer Aspire 5050-3242 Notebook
Every time I try to hotsync-my palm tx shuts down and reboots-to preferences and set date-set time-why? and what can I do .DR J
Probably and error, back it up and give it a hard reset. Also, after any reset the first screen it always shows it to set date and time.
Jan 15, 2010 | Palm TX Handheld
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Computers & Internet
Blue screen
unistall recently installed hardware or software and try otherwise format the system and reinstall operating system it work ok, till the same problem if you have two rams remove one ram and check
Mar 26, 2008 | EPoX EP-8KHA+ Motherboard
My computer went back to older clock date as 1610
try starting your computer in safe mode and see if you can do anything productive there, like scanning for viruses or spyware. also check if you can do the following:
CTRL+ALT+DEL (open task manager)
goto Start>Run>Regedit (open registry editor)
goto Start>Control Panel>Display>Properties (change display settings)
right click on clock at tray and change the current time to correct settings
if you cannot do any of these activities, then your computer may probably been compromised by a virus or malware.
Jan 02, 2008 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Computers & Internet Logo
David Payne
David Payne
