Question about Canon PowerShot A540 Digital Camera
Dropped camera now memory card is locked - Canon PowerShot A540 Digital Camera
    Genius:
  • 1,177 Answers
SD memory cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
I don't see why dropping the camera should cause the card to become locked though. Maybe there has been some damage to the connections to the card.
Posted on Nov 09, 2010
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
Have 4GB scandisk ultra...memory card when i using that i dropped.. that lock nob is gone and if i use in my camera says write protected.. pl. help me fix that lock nob again - thanks
You may be able to take a knife blade and still slide the tab...if it is completely gone then you may no be able to unlock the card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Apr 23, 2011 | Cameras
I had a canon digital camera my memory card of that camera got locked can u help me to unlock it.
Remove the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it reports locked again, carefully remove the card to see if the tab has moved back to the locked position.
If the tab is moving to the locked position during the insertion process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot. If you never locak the card - you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera.
Sep 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
My sister dropped my camera a while go and it now says "protected card"...how do i fix this???
I am surprised that nothing else has malfunctioned since dropping your S700. Remove the SD or XD memory card from the camera and make sure that the little slide switch on the memory card is in the "unlocked" position. Replace the card back into the camera (make sure that the switch doesn't slide back into the "locked" position again). Some memory cards, especially off-brand ones have very loose lock/unlock slide switches. I had to jam one into unlock mode by shoving a tiny piece of plastic into the slide slot. If that doesn't solve the problem, try using a different memory card and see if the results are the same. If this advice has solved your problem, please rate my answer accordingly. Good luck.
Jul 05, 2009 | Fuji FinePix S700 Digital Camera
Locked memory card...
hi crazytami,
the memory card on your camera is SD. on the side of the card you should be able to see a whitwe toggle switch, try to put it to the left, then try it again on the camera, if not, then try the switch on the right then try it on the camera.
one of them should unlock the memory card. if not, please let me know.
regards,
voodoo
Jun 07, 2009 | Canon PowerShot A460 Digital Camera
The card is locked]
there should be a little swith on the side of the card. switch to the opposite and then try
Mar 28, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Error when turned on, "Memory card error"
if it is an SD or SDC card the check the cord for a lock on the upper left side. This will prevent a lot of functions.
Jan 15, 2009 | Cameras
EX-Z850 Casio Camera
Same problem. My camera is 3 weeks old. I dropped it at a short distance onto a wooden floor and it immediately said my memory card was locked. I took the memory card out, it was not locked. I tried 4 different cards and they all say the same thing. If I take the memory card out, the camera runs fine on internal memory, but only holds about 8 pics. I've tried everything. Please help!!
Dec 20, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot A540 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
