Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Where can i find my Wpa key on my router ? - D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
  • 1,679 Answers
This Utility program from HP will help you locate few details on your network
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Regards,
Ron
Posted on Nov 09, 2010
Where can I find the WPA or WPA 2 Key on my Cisco N?
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 19, 2011 | Cisco Linksys Wireless N Home Router...
Need to get wpa encryption key
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryption keyand this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Feb 27, 2011 | Zoom (5590-00-03) Wireless Router (G66115)
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Jan 02, 2011 | Video Game Consoles & Games
When i connect i get this message' your wpa key you entered may not be correct"
Jan 01, 2011 | Sony PlayStation Portable (PSP) Console
I lost my wpa key? Can I find this somewhere?
Yes, you can get the wpa key from the setup page of the router.
Type 192.168.2.1 in the address bar of your web browser.
By default, leave the password blank.
Once in the setup page, go to Wireless > Security.
You will find there the WPA pre-shared key.
I hope this helps!
May 11, 2010 | Belkin (F5D8231-4) Wireless Router...
Cant find my wpa # needed to reconnect my router (TM-G5240) to my x-box live account
For routers, there no way to see what the WPA key is. Once you check the Web UI of the router and check the security, all you will see are asterisks (*********). Because WPA is a security and needs to be hidden. As the owner of the router, you should always remember what your WPA key is.
In order to resolve this issue, you need to reset the router back to factory default, set up a new WPA key and save it.
Or you may contact the manufacturer of the router and see if they have a record for your router
Have a great day!
Oct 29, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
I don't know the WPA TKIP key and I have a router my psp wont
The WPA key is the router wireless password the wpa key can be found on the router page that can be accessed by the computer
so we need to click on start go to run and type cmd nd click ok in the black window type ipconfig and press enter note down the default gateway now open up a internet explorer and in the address bar that is the www bar type the default gateway ()ike 192.168.1.1) now if it asks you for a user name and password then try these combinations user- admin pass - admin
user- admin pass- password
user- admin pass- (blank)
the router page will open up now go to wireless then wireless security and you can find the key over there
note down the wpa key and close the page now enter it in your psp
Aug 10, 2009 | Sony PlayStation Portable (PSP) Console
WPA KEY
The WPA on your wireless router can be found in the user inser interface itself.
The link below will give you instructions on how to "enable" the WPA on most Belkin routers, along the way, it will show you where to get the WPA key
http://www.belkin.com/support/Network_Support_Wizard/Enabling_WPA_security.asp
Hope this helps out, if you have other questions just let me know
Nov 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Archos 704 WPA/WEP
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Dec 02, 2007 | Archos 604 Digital Media Player
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
56 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
