Question about Kenmore 600 6965 Electric Dryer
I have a 110.60902990 Kenmore dryer and I can see that the belt is off of the tub. Can you please tell me how to get to the internal parts of this machine? I have removed the front panel, which enabled me to see the belt.
  • 1 more comment
  • michael_w383 Nov 09, 2010
    I just picked up the belt and will jump in later this evening. I really appreciate your solution and even more so, your follow up. If I run into any trouble I'll let you know.
    Thank you!
  • michael_w383 Nov 10, 2010
    The information I received from jyackle5 was very helpful and I was up and running in no time!
    Thanks jyackle5,
    The information you forwarded to me was very helpful and I was up and running in about an hour. I'm amazed the dryer was able to run at all due to all of the lint that was caked all over the machine especially the motor. I think I filled up my shop vac with lint.
    Thanks again!
    Mike
  • 8,197 Answers
  • Jyackle5
    Jyackle5 Nov 09, 2010
    Would like to know if you have fixed the dryer. If you need more help please fill free to ask.
  • Jyackle5
    Thank you for the reply back. I will be online most of the night so I am willing to help you. Also If you do get it fixed please fill free to rate if you would like.
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Kenmore 96282100
Some models you can replace by tipping dryer on its back. Tough part is sneaking the belt between frame and tub. Otherwise remove back panel, remove lint screws, remove control board. Now remove the shell and you can easily replace belt. This is a def diy project. Check youtube for general description. Whirlpool and roper would be similar.
Jan 10, 2014 | Dryers
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Sep 24, 2011 | Kenmore 63942 Dryer
How do you replace the drive belt in a kenmore dryer model 88042
Pull the fron off. Remove tub, should have a spring loaded idler pulley next to the motor. Make sure that it is not broke and spins freely. Also check tub support rolers on each side. They shoule spin freely. If ok, put belt around tub, install tu. Put belt around spring loaded pulley. May need a hand holding tub while you install pulley. Put front on. Make sure the fron of cover fits inside the tub seal. Good luck. email me with issues, bobby.crochet@lyondellbasell,com.
May 14, 2011 | Kenmore Dryers
Hello
You are sure the element heats up? Belt around drum tight? Drive motor getting power from relay
Mar 09, 2010 | Kenmore 63942 Dryer
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
On my kenmore over/under washer water level switch not working
external part of switch can be cleaned with cotton swab and rubbing alcohol.
The internal parts can be cleaned with a can of electronical cleaner
Jun 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore dryer will not turn on
Sounds like a classic broken Belt. You'll have to take the front or top off to gain access to the belt and it is wrapped around the TUB. If you can pull it up and down with no problems its the belt or the idler tentioner that keeps the belt tight.
Possibly its also the tub rolers or bearings but if you can push the tub from the inside by hand you will know if its in this area or not. If it turns freely then the belts off or broke cause when its on and tight you anct make it move very far. Important not to make the tub turn back wards too far especially if its tough to move. If its loose to move then either way usually dosnt hurt anything.
Mar 02, 2009 | Kenmore 659 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 600 6965 Electric Dryer Logo
208 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
