Question about Namsung Car Audio & Video
Need namsung car radio model db1210 color code wiring info
natenash7986
  • 53 Answers
SOURCE: Color code for wires for DEH-P4400 PIONEER radio
red-------ignition
yellow--constant
black---ground
white----drvrs front speaker
green---drivrs rear
grey-----pass front
purple--pass rear
Black indicators on the speaker wires are negative
blue-----remote turn on
orange--dimmer
Posted on Sep 01, 2008
fcsr
  • 43 Answers
SOURCE: Need info on how to wire a radio in a 1994 nissan pickup
Hope this helps, please see diagram.
Posted on Nov 17, 2008
SOURCE: need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Posted on Jan 25, 2009
  • 290 Answers
SOURCE: need wiring diagram for radio on 96 mercury sable
http://www.the12volt.com/installbay/stereodetail/1500.html
Posted on Mar 23, 2009
  • 256 Answers
SOURCE: I need to know which color wire is for what replacing radio
Normally you red wire is the battery+. Black is ground-. Yellow should be battery backup which should go to your ignition. You wil then have either two sets or four sets of wires depending if its a 2 or 4 channel radio. For instance,Brown, and brown with a white stripe- White and white with a black stripe and so forth. these will be you speaker wires. In every instance you wire with the stripe will be your negative.
Posted on May 05, 2009
I need the order of the color coded wires on the conector for a Dual model xd122 please
If you are installing a radio, I recommend you purchase a wiring harness. You will hook your radio up to it and then be able to "plug" your radio in. It has the wiring color codes on the package.
Sep 06, 2011 | Car Audio & Video
Need wiring diagram for older (DB1210) AM/FM/CD player. It has what wires what on bottom but, I don't have plug for it to know which wire is which. Thank you for any help, Rick
Rick, your best solution may be to open the stereo up. In some late model stereos the board is labeled. For example you may see +B, for +12 volt, ign for ignition, gd for ground, etc., I will try to find more information for you but try the above and see if it helps. Thanks.
May 27, 2010 | Namsung Car Audio & Video
How do you add an out put for a ipod aux
if this radio has a set of rca inputs on the back of the radio you can buy a patch cord wire that will plug right into the ipod
Apr 25, 2010 | Namsung XD-6110 CD Player
Need wiring plug for a model DB1215 am/fm/cd receiver that was lost but we want to keep the radio unit
Just bought the DB1215 Model--Can you tell me what is the best size speaker to use and how many?? Thank you Dan
Oct 12, 2009 | Namsung Car Audio & Video
Car Audio & Video Logo
241 people viewed this question
Top Namsung Car Audio & Video Experts
xxxxxx xxx
Are you a Namsung Car Audio and Video Expert? Answer questions, earn points and help others
