Kyocera Mita 1635 is giving error C0180, I can't find out what this error means. Please help. Any advise on solution will also be appreciated.
  • 541 Answers
SOURCE: Mita DC1435 Copier shows a C63 error message
you have a fuser code. you will need to test the fuser lamp, thermo fuse and thermistor with a vom with machine umplugged. open the front door and the clamshell. remove the orange fuser cover. t. remove the back cover. remove the bottom black cover. unplug the lamp, and thermistor. go to the fron of the machine. just to the right of the fuser on the frame is a black screw. remove it. now tip up the fuser 97 degrees and slide it to the left it will come out. now test the lamp with ohms, continuity, do the samae for the fuse. you will need ti remove the thermistor with one screw. put your finger onit. put he meter at 200 ohms and it should change vlaue. good luck
Posted on Dec 26, 2009
SOURCE: kyocer mita km-1635
thanks for the help. i already called the kyocera distributor here in the philippines and they guide me how to reset the unit... and im thankful that no parts have been damaged. thanks for your time.... God bless!
Posted on Jul 27, 2008
SOURCE: Copystar 1635 Copier
C3100 Scanner carriage problem The home position is not correct when the power is turned on or copying the document placed on the contact glass. Poor contact of the connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Defective scanner home position switch. Replace the scanner home position switch. Defective engine PWB. Replace the engine PWB and check for correct operation. Defective scanner motor. Replace the scanner motor
Posted on Aug 14, 2009
bolinlamar
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
  • 36 Answers
SOURCE: MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Posted on Apr 09, 2010
Km2035 error J00 kyocera mita
J00 is an unidentified jam. Means that a paper jammed in the machine and the user switched the machine off and then on again. So the machine lost the ability to inform the user where the jam is. As a result the user has to find out where the jammed paper or piece of paper is.
Jul 16, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
ALL KYOCERA MITA 1620 ERROR CODES
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Kyocera-Mita&model=KM1620
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Km 1635 c-3 error what is a problem
Kyocera mita km 1635-installed new drum but printing blank papers
Sep 06, 2013 | Office Equipment & Supplies
C-6000 error
plz my printer is Kyocera TASKalfa 220 and I have error c-6000.
can you help me to fix it ?
May 05, 2009 | Office Equipment & Supplies
Model no. of the copier
PLease communicate to sunil@rexrotaryindia.com.
We are national distributors for Kyocera copiers in INDIA though our subsidiary XPSL.
Our technical team can surely give you a solution.
Cheers
Sunil
Aug 17, 2008 | Office Equipment & Supplies
Open Questions:
278 people viewed this question
k24674
