Question about Nintendo Wii Console
My wii will not read the disks - Nintendo Wii Console
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
This is a problem occurring in all the wii consoles....... this is mainly because of the poor quality of the disc.....as a result it leads to the damage of ur wii lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if it's working good then better download this Repair Guide for further information .........
CLICK HERE to download
Posted on Dec 31, 2010
Wii console not reading disk
check if the disk is a genuine wii disk and not burned, if its burned the wii wont read it without the correct wii brew software installed.
Oct 31, 2011 | Nintendo Wii Console
What's your problem?the wiw has trouble reading the disk
Your WII is having trouble reading disks? Try using a dvd/cd ROM cleaner disk. Run the cleaning disk in the WII a couple of times and try inserting your game again. If it still does not read the disk, try cleaning the game disk itself with a lint free cloth and alcohol. make sure to dry the disk completely and never wipe in a circle. If this does not solve the issue, try playing the disk in another WII to figure out if the problem is isolated to the disk itself. If the disk plays in another WII, then contact the manufacturer and send the console in for repair.
Oct 09, 2011 | Nintendo Wii Console
When disk is installed the Wii Menu comes up but the disk is spinning and does not show the name of the disk in console.
What kind of disk is it? If it's a game then the disk might be damaged, meaning you'd have to get a new one.
It could also mean the disk drive in your Wii is broken. If other game disks work it should be fine, though.
If it's a DVD or a music CD, it's the same story - the disk must be damaged, or it's possible it's a format the Wii can't read, in which case there's nothing you can do.
If it's a disk you burned yourself, your Wii probably refuses to read it. Nintendo has restrictions on what kind of disks the Wii will read to prevent piracy.
Mar 05, 2011 | Video Game Consoles & Games
I have the same problem i try two diferent disc y nothing happen. same error . i dont think is my wii console.
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. I like to use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, which pack more info onto a disk (Super Smash Bros. Brawl and Metroid Prime use dual layer discs). If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. If all fails and still you Wii cant read any disk it only means that the Wii is malfunctioning.
Thanks for Reading. Thanks for using Fixya.
Feb 06, 2011 | Nintendo Super Smash Bros. Brawl for Wii
My wii says its unable to read disk on all games including new ones what can i do
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii.Since that your Wii is having a problem reading al disk there's might be a problem with it. Some older Wii units also have trouble with dual layer discs, which pack more info onto a disk .If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. If still having an issue better call Nintendo for further Support. You might have a Bad lens on your Wii.
Thanks for reading. Thanks for using Fixya.
Jan 31, 2011 | Video Game Consoles & Games
My wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Jan 28, 2011 | Video Game Consoles & Games
Wii will no longer read wii disk and tried different wii disk.
try unplugging it for at least 5 minutes and then plug back in and retry.
Jun 03, 2009 | Nintendo Wii Console
Wii
It is obvious that your wii console is now unable to read discs because it had a numerous disc error, check your warranty and replace the wii console.
Nov 09, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
