Service No. 37-1A Mr. Sharpy pencil sharpener. How do you open it to put in new batteries?
The bottom just pops off. Insert 4 new AAs.
Posted on Mar 23, 2011
Tip
How to build get lead out of your pencil sharpener!
Your lead is stuck in you sharpener and you have 5 more minutes until your test is collected! I'm here to show you how to get a lead out of your sharpener easy and quickly! First, if you have to remove the lid, then take a something sharp, next find the side of the medal where you can see the lead. Finally take your sharp thing and push up towards the hole where you put your pencil, if it doesn't come out after a bit, lightly bag it on you desk, it should come out fine!
on Dec 12, 2014 | Office Equipment & Supplies
Tip
How to sharpen a pencil so the tip doesn't break
When I was in school it would always frustrate me that the tips of the pencil were always breaking in the sharpener. It took many tries of turning the pencil and turning the sharpener, different amounts of pressure and I finally found the secret.
Sharpening a pencil is a very easy thing to do. When you are using a hand sharpener, either a small plastic one with a cartridge to catch the shavings or the really small ones that don't catch the shaving, your put the utencile end of the pencil into the sharpener keeping it has straight as possible.
Applying a little pressure turn the pencil in the clockwise motion (you can turn either the pencil or the sharpener both will work). The shavings will begin to fall off and you keep turning until either you are satisfied with the sharpness of the tip or the shavings stop coming off. Make sure that you don't put more pressure on the pencil to make the shaving keep coming off because that will make the tip break and get stuck in the sharpener.
Pull the pencil out and clean the sharpener, it should be good to go. What I discovered was that if I had dropped a pencil a few times then the lead inside the pencil would be broken and this would cause the tip to break after sharpening. Treating your pencils nicely will keep them from breaking tips when you sharpen.
on Jan 30, 2014 | Office Equipment & Supplies
How do I open the prismacolor pencil sharpener
Unlatch the clear Top Cover to lift up like a Toilet seat lid which is hinged by a SUPER FLIMSY strip of plastic to the opposite side of the unit. This done with the Sharpening Holes facing UP.
Sep 28, 2014 | Sanford Corporation Prismacolor Premier...
What kinds of pencil sharpners are there?
There are many kinds of pencil sharpeners that have been developed through the years.
The most common ones, the manual sharpners, can be of the following kinds:
Mechanical sharpeners: a portable variety, usually small and in the shape of a rectangular prism. The blade inside rotates around the pencil, sharpening it. The shavings emerge through a slot.
Blade sharpeners: small and portable, hold replaceable shaving razor blades or permanently fitted blades. They work similarly to knives, but in a more convenient and safe way.
Cylindrical cutters: larger variety, stationary, powered by a crank. One hand holds the pencil, the other turns the crank.
Another common pencil sharpener found often in offices is the electric sharpener. It works on the same principle as the manual sharpener, but the blade rotates quickly thanks to an electric motor, either powered by batteries or plugged into the electrical system.
There are still people, mainly artists, that sharpen their pencils with a knife.
Oct 06, 2013 | Office Equipment & Supplies
When was the pencil sharpener invented?
Before the pencil sharpener was invented, pencils were sharpened by shaving away the wood with a knife. The first pencil sharpener was invented by Therry des Estwaux in 1847.
What is a pencil sharpener?
A pencil sharpener is "a device for sharpening a pencil's writing point by shaving away its worn surface. Pencil sharpeners may be operated manually or by an electric motor." (wikipedia)
Where can I learn how to sharpen pencils with a knife?
There's this guy, who apparently is a proffesional pencil sharpener and he teaches on this video how to sharpen pencils: http://www.youtube.com/watch?v=spMaP-_Cq_8
Jan 24, 2013 | Office Equipment & Supplies
Is there a pencil sharpener that I can sharpen several pencils at once?
I don't think there is, but there's a sharpener with different size holes for different types of pencils: http://www.officedepot.com/a/products/744792/Stanley-Bostitch-Classroom-Electric-Pencil-Sharpener/?cm_cat=2000000361
When I insert a pencil into my brand new school pro sharpener, the blades spin, but do not sharpen.
The website says to check and make sure its not jammed with pencil lead or something else. unplug it take the shavings bin out and flip it upside down so you can look into the sharpeners. Rotate them by hand till you can see the open side of the blade then use a unfolded paper clip and slide it in the path the pencil would usually take. This should knock anything loose the would be jammed in there. If it passes through to where you can see the point you should be clear. If you didn't dislodge anything or it still doesn't sharpen but the blades spin when you try to use the sharpener, then there is a tab that can get jammed back that needs to be in the foreword position. The tab is located where the tip of the pencil would point if it was actually being sharpened. if you run the paper clip through the machine (just like when trying to dislodge something) the tip of the clip will touch the tab. make sure its not jammed back (away from the opening/pencil) it should be as far forward as possible for the blades to engage. I hope this helps! This has been jammed many times by pencil shavings or gunk on my wife's (elementary school teacher) pencil sharpener.
Sep 22, 2011 | X-Acto XActo School Pro Electric Pencil...
104 people viewed this question
k24674
