Question about GE (PSS26MSRSS) Side by Side Refrigerator
Correct operating temperatures
What are the correct operating temperatures? i get a lot of variation.
  • 3 Answers
According to the manual it is 0 degrees for the freezer and 37 degrees for the fridge.
Posted on Jun 23, 2008
    Problem Solver:
  • 4 Answers
I run my own aplliance shop out of my house and we set them at (freezer about a 5 6 depending how many numbers you have on the dial) and the fridge should be set higher like a 7 8. try to keep them about two mubers apart. It also will varie on how much food you have in the fridge too. Hope this helps :)
Posted on Jun 20, 2008
Need to know the location of both crankshaft position sensor on 2008 Chevrolet hhr plz thx
Only has one crankshaft position sensor ,an cam sensors . To change the crank sensor u would have to pull the starter ,located above starter .
Camshaft Position Sensor Replacement - Intake Camshaft Position Sensor Replacement - Exhaust
After a crank sensor replacement a
Crankshaft Position System Variation Learn has to be done !
Important: The crankshaft position (CKP) system variation learn procedure is required when the following service procedures have been performed, regardless of whether DTC P0315 is set:
Engine replacement
Engine control module (ECM) replacement
Crankshaft damper replacement
Crankshaft replacement
CKP sensor replacement
Any engine repairs which disturb the crankshaft to CKP sensor relationship
Important: The scan tool monitors certain component signals to determine if all the conditions are met to continue with the CKP system variation learn procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool monitors the following components:
CKP sensor activity--If there is a CKP sensor condition, refer to the applicable DTC that set.
Camshaft position (CMP) signal activity--If there is a CMP signal condition, refer to the applicable DTC that set.
Engine coolant temperature (ECT)--If the engine coolant temperature is not warm enough, idle the engine until the engine coolant temperature reaches the correct temperature.
Apr 04, 2016 | Chevrolet Cars & Trucks
Where is the crankshaft position sensor located on a 2008 HHR 2.2 is that ecotec engine
My info says it is located above the starter motor. Info says to remove the starter.
The info also says you have to do a crankshaft variation relearn procedure. I can't help you with that procedure.
Nov 18, 2015 | Cars & Trucks
My Danby refrigerator shows a lot of temp variance. A thermometer on the top shelf shows 40 degrees, lower shows 32, is this normal?
if the door has been opened or used for a number of times ,that variation will be around normal
the system works like this
the fridge cools air from the bottom up as cold air falls to the bottom of the fridge
if the door is not being opened ( over night) the whole compartment becomes to the same temperature as set by the thermostat and that is when the fridge cuts of
Now if the door seals are leaking cold air out at the bottom then the whole compartment will never get to the same temperature ( your variation)
similarly if the door is constantly being opened , the cold air at the top of the compartment replaces the cold air at the bottom that has flowed out onto the floor on opening the door (again your variation)
so you have to possible items to check
1 are the door seals in top condition and 2 is the door being opened too much in short periods of time
Jul 18, 2015 | Danby Refrigerators
Whirlpool RBS245PDS18 temperature calibration?
If it is new contact the people that sold it to you for warranty repair. If not Just set it higher, that is a lot lest costly then getting the appropriate equipment to calibrate it. You can also replace it.
Dec 19, 2014 | Whirlpool Ovens
Gmc 98 sonoma pu with p1336 error
Hi there:
The crankshaft position (CKP) system variation learn feature is used to calculate reference period errors caused by slight tolerance variations in the crankshaft, and the CKP sensors. The calculated error allows the powertrain control module (PCM) to accurately compensate for reference period variations. This enhances the ability of the PCM to detect misfire events over a wider range of engine speed and load.
Conditions for Setting the DTC:
The CKP system variation values are not stored in the PCM memory.
Action Taken When the DTC Sets:
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC:
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
The CKP system variation values are not stored in the PCM memory after a learn procedure has been performed. If the actual CKP variation is not within the CKP system variation compensating values stored in the PCM, DTC P0300 may set.
The CKP system variation learn procedure is also required when the following service procedures have been performed, regardless of whether DTC P1336 is set.
An engine replacement
A PCM replacement
A harmonic balancer replacement
A crankshaft replacement
Any engine repairs which disturb the CKP sensor relationship
If the CKP system variation learn procedure cannot be performed successfully, check for the following conditions and correct as necessary:
A damaged reluctor wheel
Excessive crankshaft runout
A damaged crankshaft
Interference in the signal circuit of the CKP sensor
A coolant temperature that is not within the Conditions For Running the DTC
The ignition switch is in the ON position until the battery is drained
A PCM power disconnect with the ignition ON may erase the stored value and set the DTC P1336
Hope this helps.
May 25, 2012 | GMC Sonoma Cars & Trucks
Crankshaft position error
Hi there:
CKP SYSTEM VARIATION LEARN PROCEDURE
IMPORTANT:
  • The crankshaft position (CKP) system variation learn procedure is required when the following service procedures have been performed, regardless of whether DTC P0315 is set:
  • Engine replacement
  • Engine control module (ECM) replacement
  • Crankshaft damper replacement
  • Crankshaft replacement
  • CKP sensor replacement
  • Any engine repairs which disturb the crankshaft to CKP sensor relationship
  • The scan tool monitors certain component signals to determine if all the conditions are met to continue with the CKP system variation learn procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool monitors the following components:
  • CKP sensor activity-If there is a CKP sensor condition, refer to the applicable DTC that set.
  • Camshaft position (CMP) signal activity-If there is a CMP signal condition, refer to the applicable DTC that set.
  • Engine coolant temperature (ECT)-If the engine coolant temperature is not warm enough, idle the engine until the engine coolant temperature reaches the correct temperature.
Also cHeck THIS LINK
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
May 22, 2012 | GMC Acadia Cars & Trucks
2008 acadia crankshaft relearn
IMPORTANT:
  • The crankshaft position (CKP) system variation learn procedure is required when the following service procedures have been performed, regardless of whether DTCP0315 is set:
  • Any engine repairs which disturb the crankshaft to CKP sensor relationship. The scan tool monitors certain component signals to determine if all the conditions are met to continue with the CKP system variation learn procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool monitors the following components:
  • CKP sensor activity-If there is a CKP sensor condition, refer to the applicable DTCthat set.
Also check THIS LINK
Freezer too cold, has frost on food and frig is freezing food on Kenmore side by side frig/freezer. Model 1065438300 Ran test sequence on front panel and all is inputs and outputs display that they are...
There should be separate temperature controls for each side correct?First,try turning the freezer side to a warmer temperature setting.Not just a little but a lot.It takes about 24 hours for it to adjust to the new temperature,but you can check on it every couple of hours.If nothing changes,it is most likely the thermocouple within the freezer half.It basically reads what temperatureyou want,reads what the current temperature is,and tells the refrigerator when to send more cold air.If there is a noticeable change,we will have to look elsewhere.A thermocouple is basically a metal rod with 2 leads coming out of it into the back of the refrigerator somewhere.It may also be small sometimes,or hidden under a plastic cover.Google thermocouple and it should show some pictures of it.They are for the most part the same with only slight variations in length or width.Greg
Nov 04, 2010 | Kenmore 53642 / 53644 Side by Side...
Tyre pressures zx12r
It should show the maximum tire pressure right on the tires.If you fill them at a gas station,I would bring my own gauge as they are rarely correct at the gas station.I would use the maximum or probably no more than 2 psi under maximum.This rating is usually for optimum performance.If you live where there is a lot of variation in temperature outside,I would check them 2-4 times per month.I live in FL and check mine every other week or once a month due to consistency in temperature.
Jul 22, 2010 | 2002 kawasaki ZX-12R
2003 Gr. Cherokee Tire PMS overactive with smaller sidewall tires
Hello partner. The difference in air pressure variations from a 16',17' or 20" tires is a non-factor. Any size tire will go up about 1psi per 10 degrees ambient temperature. The recommended pressure for an 03 Grand Cherokee is 33psi. So if it's a rainy 55 degrees in the great northwest when you set your pressures the temperature on your trip to Death Valley would have to climb to about 175 degrees. On a different note maybe your alarm just isn't calibrated correctly.
Apr 10, 2009 | 2003 Jeep Grand Cherokee
GE (PSS26MSRSS) Side by Side Refrigerator Logo
155 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
