Question about Dell M5200n Laser Printer
Dell printer asks for manual feed but tray 1 has paper, and asks for plain paper in tray when it already has it. have reset to letter/plain paper about 100 times...have reset factory defaults, cannot change universal paper size...a small black "arm" was found near printer...is this a piece that is causing all of this?
Soulvisitor
  • 1113 Answers
SOURCE: tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Posted on Dec 18, 2007
SOURCE: Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Posted on Jul 11, 2008
SOURCE: Dell 3110cn Error 024-695
Hey guys. Dont assume i know alot about printers, because i dont, but after some looking around the loading tray i found the problem. At the right side of the loading tray, more towards the back, are 3 white plastic things that sorta stick out, however one of them on mine seemed broken and didnt stick out, these devices seemed to be attached to some sort of lever, anyways... i just stuck a compressed lump of foil underneath it to make sure it did stick out, not exactly the best of solutions but it worked for me :) . If you flip the printer upsidedown you can notice to which parts the white deivices correspond too. i hope this helps someone, and that it wasnt too confusing :P.
Posted on Apr 17, 2009
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
Posted on Jun 11, 2009
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
Tray 1 doesn't feed while tray 2 has paper, after I empty the paper from tray 2, tray 1 work fine.
if you setup tray 1 any type, any size and tray 2 to plain, and letter size, it will allow you to use tray 2 for your plain letter jobs but will pull from the manual feed tray first only if the paper is in the manual feed tray if this makes any sense to you... please mark this as a fixya...
Nov 24, 2013 | HP LaserJet P4015N Printer
Lexmark e352dn-load manual plain letter message
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputer is sending other paper size/type settings.
Aug 20, 2010 | Lexmark E352dn Laser Printer
When we send any file to print it is giving load manual feeder error
This will set up your printer for plain letter paper and should relieve the manual feed error unless your computer is sending other paper size/type settings.
Aug 09, 2010 | Lexmark X364dn All-In-One Laser Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Dell Laser Printer 5100cn Load MPF Letter Plain 1 !
Are you trying to use the "MPF" (Manual Paper Feed) tray?
If you are then the manual paper feed tray is usually a fold down flap at the back of the printer. It only accepts on piece of paper at a time.
However, if you are just trying to print to the printer's default tray, then you need to check both the "Page Setup" in the application and the printer driver properties to make sure that you are calling the correct paper tray.
Don
Nov 18, 2009 | Dell 5100cn Laser Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Tray 1- load plain letter
Linda,
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Error Message on Dell 5100cn
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Dell M5200n Laser Printer Logo
231 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
