Question about Sony Ericsson K800i Cellular Phone
PROFILES icon missing and an ERROR message is shown at start up
I bought a new k800i 2 weeks ago,ever since the first time i turned it on, a message AN ERROR IN THE MENU.ML FILE OCCURED THIS MAY RENDER THE MENU UNUSSABLE,the profile icon is missing,i have no acces to the my aplicattions and the games,my phone is so slower now, please help...
  • dime_richie Jun 17, 2008
    10x for the advice but i tried that one,i did restart and format the memo stick,but the problems still occures,this phone i bought from mente negro and i live in macedonia so the warranty is usseles here,so if i try to re-install a new software would that help? i tried to update the phone but it says that i am using newest software-any other suggestions???
    sorry but it didnot help me that advice u told me,how would u like me to rate u othervise? sorry for being to realistic about rating u... any way 10x for the offer of solutions
  • 983 Answers
Try giving the restore factory settings option(or reset option) ....
(it will ask for the security code or password) ...
after giving this all of your problem will be solved ...
there is very less chance if you still persist any problem then just may use of warranty as it is new one .....
any doubts reply me
i am always here to assist you
thank you
bye
Posted on Jun 17, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 17, 2008
    i would have told you other solutions but you already rated me as thanks for trying ...
    now no use of giving you solution
    actually u could have waited to rate me after seeing next comment ...
    whatever it s over forget it ...
    be trying to repair your cell asking other persons ... hahaha.....
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Solution:
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Wont run
Aug 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Motorazr V3 Status indicator no longers displays envelope for voice messages
Why am I receiving a memory full notification? space.gif space.gif answer.gif Memory full warning notifications are shown once the SMS memory reaches 80% full, which is 80 out of 100 SMS.
The notifications show up every time on receiving a new message. On reaching 100%, "Memory full notification" message is shown and no new messages will be received until we make space for incoming messages by deleting some from the inbox.
Memory full warning notices are shown only if "Auto Erase Inbox" is set to Off in Messaging settings (Menu -> Settings -> Messaging).
If set to On, then these notices are not shown. By default this is set to Off.
Oct 22, 2008 | Motorola Mobility RAZR V3
Printer reads RIGHT CARTRIDGE INCORRECT
If you have purchased the cartridges directly from dell , it will be covered under warranty for 2 years for hardware errors and you can call dell on 1800 624 9896 and get the cartridge replaced , even after the replacement of the cartridges if you have the similar issue then its an issue with the printer and needs to be replaced.
Jun 24, 2008 | Dell 922 All-In-One InkJet Printer
ERROR OCCURED IN THE MENU.MLFILE THIS MAY RENDDER THE MENU UNUSSABLEthis message shows allways on start up
hai,
it seems your mobile phone and the SDmicro card are infected with some virus. try software upgrade using the PC suit
if its not working, contact the nearest service centre.
good luck
Jun 17, 2008 | Sony Ericsson K800i Cellular Phone
Memory card
format your memory card, but all your data will be lost
Jun 15, 2008 | Sony Ericsson K800i Cellular Phone
PagePro 1350W
Time has nothing to do with how long a toner cartridge will last. What is the page count on the cartridge?
Don't expect too much from it if it is the original cartridge that came with the printer as they have a very short fill.
Dec 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
Mobile phone
contact ur service provider to chk abt si registry or sim validity....if it is all fine then change the n/w settings in ur fone and after that reinsert sim,,,,any issues pls go to care centre for chking of sim slots....
Oct 25, 2007 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
158 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
