Question about Lindhaus 380 Diamante Bagged Upright Vacuum
How do I get a online schematic of the Lindhaus 380e w/ RX Hepa Power Nozzle? mikejwyman@gmail.com
Need brush bar and bearings
The brush roll you need has been discontinued. I have one in stock at this time. ($49.99) Please contact me if you want it.
May 12, 2014 | Eureka 8853AVZ Capture Plus Pet Lover...
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
Sucton motor doesn't come on
If the debris cleared itself, it may have gotten into the vacuum fan assembly and jammed the motor preventing turning. Also, check the vacuum motor brushes and springs for damage. Hope this helps.
Dec 05, 2009 | Lindhaus HEPA 14 HealthCare Pro Bagged...
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
Where to buy bags
You did do a google search on this ... right? And what about the place where you bought the machine? It appears that you MUST go to an authorized dealer for parts and service.
http://www.lindhaususa.com/ Go here and search for a dealer in your area.
or
http://www.lindhaususa.com/dealers.php find a dealer here.
still can't find it ... contact the company http://www.lindhaususa.com/vacuum@lindhaus.it
Sep 21, 2009 | Lindhaus Vacuums
Wire came loose, can't figure out where it belongs
Maybe one of the wires that leads to the power head?
Aug 11, 2009 | Lindhaus HF6-12 Canister Vacuum
I have just purchased a used Miele S528 and the power beater bar attachment is a Lindhaus. Is this ok?
as long as all the wiring on the power nozzle looks secure and it plugs safely into the end of the hose then you should be fine.
May 10, 2009 | Miele Filtration Guard S528 Canister...
I have no suction on the Lindhause healthcare pro Hepa
Make sure that the on switch is in the upright position. Down won't give you give you suction when vacuming.
Make sure that the hose is securly in the lower part of the vacuum.
Test the hose with your hand before you put it back to see if you're getting air sucked in through hose. If not it must be clogged up somewhere. You might contact Lindhause home base.
Feb 23, 2009 | Lindhaus Healthcare Pro 14 Bagged Upright...
Lindhaus 380 Diamante Bagged Upright Vacuum Logo
62 people viewed this question
Top Lindhaus Vacuums Experts
vince
ray gallant
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
