Question about Samsung SM 352 CD-RW/DVD-ROM Burner
Will not reconize cd or dvd
I was working perfectly and just stopped working. Any suggestions please?
    Novelist:
  • 119 Answers
Try this:
Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Posted on Jun 19, 2008
Cd reconize wont
An external DVDROM will show up as a USB device.
Jan 23, 2014 | Compaq Presario 700 470024-192 Notebook
CD/DVD Drive stopped working. When I insert a
Unfortunately, if device manager is not reconizing your CD drive, your drive has gone bad and needs to be replaced.
May 04, 2010 | HP Pavilion dv9000z Notebook
Hitachi DVD-ROM GD-S200
Did it come with a disk.? You may have to download the driver from manufacturers website. Good luck. Please rate me
Jun 18, 2009 | Hitachi (GD-S200) (GDS200) DVD Drive
OS is Windows XP Professional CD drive will not reconize a DVD+R for recording data. The drive is a HL-D-ST CDRW/DVD GCC4244.
A CDRW/DVD is a CD-burner and DVD-ROM combined unit. It is not meant to record DVDs only CDs.
It will not recognise a blank DVD as it is unable to read any file system.
Jun 01, 2009 | Dell Computers & Internet
No sound output and will not reconize Dvd's, but will reconize cd's
I'll take that as a no,
In fact the default for most types of media is media player but it doesn't include all of the relevant codex's you require for every type of media by default.
Most manufacturers include this software with their computers/DVDROM's but not always.
The reason I assume it is your codex not being installed is simple, you can play CD's, that means the drive works, media player works, sound card works and speakers work. The only common problem that would cause this is a missing or corrupted codex.
try something for me and let me know if it solves the problem.
Install VLC player http://www.videolan.org/vlc/download-windows.html
Then try to play the DVD using VLC player. If it asks to update itself, let it.
Comment back here once you have tried and let me know how you make out.
Chris
May 20, 2009 | NEC (ND-3540A Black) Burner
CD does not work at times
Sounds to me like there could be a loose connection where it connects cd/dvd drive
May 20, 2009 | Acer Aspire 3000 Notebook
Dvd player on computer doesn't work.
i have a toshiba satellite. my d drive is not reconizing a cd or dvd when it is inserted. it just spins the stops. i have windows xp home ed.
Feb 18, 2009 | Computers & Internet
Hl-dt-st dvdram gsa-t40n ata device driver curupted
Problem occurs when vista registry entry is corrupted. The steps to resolve this are as follows:
  • run regedit.exe
  • navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  • Depending on your particular setup, you may have multiple entries for {4D36E965-E325-11CE-BFC1-08002BE10318}. If this is the case, find the one that says DVD/CD-ROM drives (under default)
  • Once you have found the appropriate key, you will see an entry that says UpperFilters.
  • Delete this key and then restart
  • (NB: Do not delete any other 'UpperFilters' key that is not in the category of DVD/CD-ROM drives, otherwise you may get the BSOD.)
This solution fixed my problem.
Dec 25, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
Blank dvd media is not reconized
1.Please cheack weather the DVD meadia is DVD R/W combo drive, 2.Then only the DVD media will be Burn or write tO the Blank dvd media & then check weather the blank cd is a dvd r/w cd.
Jun 29, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
The ROM reads DVDs but does not read CD.
Hi ya! 1. What new software did you install '15 days' ago? 2. Did you watch and download any free or paid XXX rated content site? Let me this: TRUTHFULLY! Hope for the best! Anks
Mar 26, 2007 | Sony (179650611) for VAIO PCG (179650611)...
Samsung SM 352 CD-RW/DVD-ROM Burner Logo
195 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
