Question about Fuji ASK-4000 Thermal Photo Printer
I havea FUJIFILM ASK 4000. The red light is flashing that indicates the machine needs to be turned off and back on. That did not help. I changed paper and ribbon and also removed a paper shred from the exit area. Same problem. I am now lost as to what to do next.
  • 1 more comment
  • jolson600 Nov 09, 2010
    I have done that semi-regularly. This time there was a very slight green shade on the cleaning cloth (which is normal for this printer) but the printer still does not work.
    You obviously exceeded my abilities as I did not know there were any batteries. Where in the worl would they be?
    They do not support the ASK4000. I tried there first. That''s how I got to you.
  • Fuji Master
  • 1,679 Answers
Try these step and it should fix the issue :
Cleaning or the printhead
The printhead is a 300 dpi thermal. If you raise the head and can see the glass face, there are 2 rows of heating elements that are used in printing.
As in all thermal heads, do not use any sharp objects to scrape on the head. I usually use a non volitile citrus cleaner or iso alchohol.
The plate beneath the head should also be checked for wear and cleaned to provide positve drive for the stock.
Regards,
Ron.
Posted on Nov 09, 2010
  • 3 more comments
  • ONE-Touch-Solution
    ONE-Touch-Solution Nov 09, 2010
    The
    printing.
    Let me know once you have tried the steps and if it fixed the issue.
    Regards,
    Ron.
    Have you tried Removing the battery and reinserting them ? If you havent, please do.
    If the steps have not resolved your problem, I request you to contact Fujifilm tech support for further troubleshooting since they are certified technicians and can give you more clear understanding on the issue.
    Click on the link to open the website to contact Fujifilm techsupport : Link
    The link for Fujifilm : Link
    ONE-Touch-Solution Nov 11, 2010
    Were you able to find solution for the problem ?
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
Fujifilm fineppix s4000
Sounds like you have the flash unit turned off.
Jan 26, 2013 | FUJIFILM FinePix S4000 / S4050 Digital...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I am having issue with my TV it won't turn on and I have a flashing red status light keep flashing can anyone help
Hi, if your tv is between 1-4 yrs old and havent replaced the lamp it might be time to do so.Mitsubishis uses Osram lamps to light up the screen and tend to last from 3000-4000 hrs normally 1-3 yrs.The Red light indicator usually indicates its time to replace the lamp.Heres the lamp you would need http://www.discount-merchant.com/Mitsubhishi-915P027010-915P027A10-Replacement-p/mitsubishi-915p027010-lamp.htm?1=1&CartID=0 On the same link it shows you how to replace it ,have a blessed day.
Apr 18, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
Fujifilm ask-4000
I have the driver disk if you need it.
Oct 03, 2008 | Fuji Pictrography 3500 Printer
Olympus Camedia C-4000 Flash Problems.. Help Please!
The flash is malfunctioning and causing the camera to not work, the flashing lights in the viewfinder is the camera indicating the malfunction. Most likely it is a board that needs repair and that'll cost a flat rate minimum $160 from OLY.
Feb 27, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Open Questions:
See all Fuji ASK-4000 Thermal Photo Printer Questions
Fuji ASK-4000 Thermal Photo Printer Logo
272 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
