Question about Rowenta Irons
I have a Rowenta "Professional"
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
Alan ang
  • 24 Answers
SOURCE: rowenta autosteam iron dz 1700 r
The electronic device is faulty and need to change inorder for the iron to work properly.
Regards
alan
Posted on Feb 24, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
  • 12 Answers
SOURCE: Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Posted on Apr 26, 2009
How to repairleak on rowenta superpress 050 I use spring water
probably can't fix
if you take it to an appliance repair ship for a quote , it will probably cost more than a new one
Spring water is very high in mineral content and that would cause the leak
best use DE-mineralized water as that is just pure water and is what is recommended for irons
Jun 08, 2018 | Rowenta Irons
How to disassemble a Rowenta DE-871
First remove screw the on the back of the iron. Next pull out on the fill tub on the front of the iron. Pliers might be needed. Another screw will seen at this time. Remove this screw and the sole plate will separate from the top portion of the DE 871.
Oct 02, 2010 | Rowenta Professional DE871 Iron
Need the circuit board for a DE-871A Iron / Iron does not turn on
The electronic shutoff light blinks but won't stay on, so the iron won't get hot. Can this be repaired? Can I disable it?
Dec 14, 2009 | Rowenta Professional DE871 Iron
My grandson knocked my Rowena Iron model DE-87.1b
go to the store get a 2 part epoxy glue follow the directions and mix the glue put it on both the knob and the part the knob goes on wait untill the glue gets tacky then put the knob back on wait 24 hrs. before you use the iron so that the glue can set
Apr 24, 2009 | Rowenta Irons
Rowenta problem
mY de 87.1C WAS WORKING AN ABOUT TWENTY MINUTES OF IRONING, THE CORD & PLUG IN BLEW & IT QUIT.
Dec 26, 2008 | Rowenta Professional DE871 Iron
Doesn't heat up...
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Nov 01, 2007 | Rowenta Professional DX8800 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Irons Logo
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
