How can i rotate the screen, i.e. screen lfescapement in delphi
Citroen Berlingo 1.9d. 2002. Fitted with DELPHI injector pump. Timing of cam belt & flywheel is by locking
I have been doing research on the Delphi pump and it apparently is associated with lucas/cav and as such is timed by the use of a dial test indicator that, through the use of a plunger and cam, runs on the cam block in the pump and determines when injection begins. Initial timing is to set the flywheel on the injection timing mark and the pump flange mark set on the timing case mark. To get it exact I would recommend that you have a diesel pump shop do the timing using the correct tools. As the pump is not electronic as such (from my research into Delphi ) it is basically a manual injector with a electronic controlled governor. Any way the best advice is to have a pump expert set the timing.
Jan 05, 2014 | 2004 Citroen Berlingo 1.9
Delphi 200 navigatar
Do you mean that you want to display what is on the built in screen onto another external screen?
Apr 04, 2008 | Delphi NAV200 GPS Receiver
Delphi nav200
Does this also happen when you reboot the unit?
Feb 13, 2008 | Delphi NAV200 GPS Receiver
I have an older model radio.. Delphi Roady 2.. gets powe to the docking station to the removalable unit but screen display will not light up.. any suggestions???
Probably the cheapest solution is to buy a used Roady2 off online bidding service like ebay and then pay the $15 to XM to switch radios. Delphi no longer makes Roady2. Probably could not repair for a cheap as you can buy used radios (around $25).
Nov 27, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
My delphi xm is frozen
Hold the up volume button and the mode button at the same time. I have to do it almost every day. This is only a problem when using the car kit. No problem at all when using with portable kit or home kit.
Dec 18, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 Problem
just hold down on all buttons.
Oct 18, 2008 | Delphi Audio Players & Recorders
Delphi MyFI
I have the same problem, and only the same few channels are shown on the channel access screen and they all have + signs.
Aug 21, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
Jul 10, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
