Question about Acer Extensa 5620 Notebook PC
Need the name of the switch that turn the lap top off when i close the lid.
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Inspirion 14z don`t shut down
go to windows control panel nad set the lap top to turn off when lid is closed.
Jun 09, 2014 | Dell inspiron 14z-n411z laptop intel
My lap top disply only black colour
A bit vague, could you be more specific to your
problem. I need more information to give a
informed solution.
Does it boot? Is there power? Possible bad monitor, CCL issue, Tiny switch stuck, that shuts down the monitor when lid is closed? Can you see the OS in a BRIGHT on the monitor? The CCL will not come on if the tiny switch is stuck in the closed position.
Nov 04, 2012 | Computers & Internet
HOW DO I TURN OFF LAP TOP.
Just keep pressing the power button.
Oct 30, 2012 | ASUS Computers & Internet
I HAVE A TOP LOADER WHIRLPOOL LXR7144EQ1. i HAVE TO PUSH DOWN ON THE LID AFTER CLOSING IT OR HAVE SOMETHING HEAVY ON TOP FOR IT TO CONTINUE TO WASH. WHATS THE PROBLEM?
It sounds like the lid switch, which senses when the lid is closed, needs adjusting. You will need to remove the top of the machine, locate the switch and move it closer to the lid actuator.
Jul 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Lid not turning washer on
Sounds like a lid switch problem most likely. When closing the lid, slowly lower it and listen/feel for a "click" when the lid is about 3 inches from being completely closed. If you don't, then you have a broken lid switch.
The model of washer you listed, TAWS800JQ, has two different possible lid switches and you get to them differently.
To get to the lid switch, you need to remove 2 screws that hold the control console in place. There is 1 on the left and 1 on the right of the console. They can either be on the front side and easy to see, or on the back side. Loosen those screws so that the console is free and you can flip it up and backwards out of your way.
One type of lid switch can be seen on the left side after you flip the control console up and back out of your way. There is just a little clip that holds it in place. The lid needs to be raised in order to remove the lid switch. Unplug the wiring harness and replace.
The other type, do this:
Then use a flat blade screwdriver to remove the brass spring clips on the left and right side of the washer that hold the front/sides/top on. Unplug the lid switch in the middle of the washer top and then you can remove the wrap-around cabinet. The lid switch is under the top and is held in place by clips and 2 screws.
May 29, 2010 | Estate TAWS800JQ Top Load Washer
Whirlpool stack washer will fill but will not progress to rest of cycle
It sounds like the lid switch is not making contact. It is a magnet located on the lid so that when you close the lid, the magnet pulls the switch closed. Make sure the magnet is still on the lid. If you washer lid will not stay open on most models, the magnet is gone because this is the same magnet that pulls the lid switch closed. If you can find where it goes, find a strong magnet and place it on the top inside rim where the lid goes when closed. Turn the machine on, let fill with water. Once this is complete and the machine should start. Take the magnet and move it around the rim until the unit starts running. If you can't get it to run, most likely the switch it's self is bad. I think you will find the magnet on the lid is gone and the machine will start running once you pass a magnet over the place where it goes. If so you will need to replace the part.
Oct 17, 2009 | Whirlpool LTE5243D Top Load Stacked...
My washer turns off when i shut the lid...turns on with weightlid
Check your lid switch. The lid switch is toggled by the action of the washer lid closing and it will not complete a cycle if it does not engage. It sounds like the switch may be loose and needs to either be adjusted, or tightened. If you need instructions, please post back with a brand name and model number so that I can explain how to access the switch. I hope you find this helpful.
Oct 04, 2009 | Washing Machines
Convertible Top Lid Not Closing
top still needs to be adjusted to fully seat properly in the trunk/boot. if the upholsterer who replaced the top is not familiar with the adjusting process for a BMW, then i would take it to a BMW dealer and have them do the final adjustments.
Mar 13, 2009 | 2001 BMW 330
LSQ9549LWO WHIRLPOOL WASHING MACHINE TOP LOAD NO SPIN @ RINSE CYCLE
You could have a bad lid switch or the hinge may need to be bent to make better contact with the switch. If your washer has a oval cut out on the right side and an actuator on the rt side of the lid... the next time it acts up don't open the lid and turn the tub, simply push down on the rt side of the lid, if it starts to work replace the lid switch. If there is no hole or actuator on the rt side, then the lid switch is on the back left corner, when you open and close the lid you should hear a click. If you don't hear a click or if you hear it when the lid is almost closed you need to adjust the hinge. There are 2 screws on the back of the endcaps on the control panel remove them and flip up the control panel, use a screwdirver to pop out the spring clamps on the rt and lt sides of the top panel. approx 3-4 inches from the sides. just insert the tip into the front most part of the clamp and pry back. unclip the lid switch, and pull the cabinet forward. You should be able to bend the hinge a little so it makes better contact with the lid switch. hope this helps.
Aug 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Acer Extensa 5620 Notebook PC Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
