Question about Canon PowerShot S5 IS Digital Camera
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the ZOOM function the photos are mostly out of focus. What can I try to take clear photos again? Thank you.
    Problem Solver:
  • 6 Answers
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Posted on Nov 10, 2010
    Scholar:
  • 24 Answers
I won't rule out a mechanical problem but there are lots of settings that could be the culprit and are more likley.
First, you could be locked in the macro setting
Second you might be set for center focusing and the camera is focusing on something in the background instead of things like people who are much closer. If you use center focus you must point the center of the frame at something as far away as the subject of your pictures, and depress the shutter half way, and then point it where you want to take the picture and depress it the rest of the way to shoot the picture.
I am presuming the pictures really are out of focus. There is a focus adjustment on the tiny view screen in the eyepiece viewer, and if that's what you've been looking though, and it's not in focus, everything will look like it's out of focus even if the camera is taking perfect pictures.
Posted on May 31, 2014
The focus will not work.
some camera have fix focus (not autofocus), read the manual, find out about auto-focusing. if it's fix focus, sure you can't auto-focus it to certain object
May 27, 2013 | SVP Aqua 5800 Orange with Micro 32gb 18mp...
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Jun 20, 2011 | Nikon D3000 Digital Camera
My Olympus e 510 is one year old. worked fine, but now is taking blurry pics. I tried all focus setting, including manual setting, auto-focus and even tried a different lens, still takes blurry pics. It...
I have the same problem and I strong suspect the circuit board is going bad. No matter what lens I use, distance from subject, etc. makes any difference. Unfortunately, the fix is about $200.00 - and having to invest $200.00 per year to keep it going is not a viable option for anyone.
Jan 23, 2011 | Olympus EVOLT E-510 Body Only Digital...
My pics on my Canon rebel eos looked clear on my camera but when downloaded to the computer they are bluury. Lanscape photos are fine but wildlife is blurred.
First of all this is a digital camera, not a 35mm film camera, but it is the same fix... You need to use a faster shutter speed for your wildlife pictures. Or use a tripod, or both. The small screen on the camera is not big enough to tell if a photo is really sharp. Also check the way you have your autofocus set up, or focus manually to test a few closer shots. It may be that the auto focus is set to focus on a part of the picture which is not the bit you are interested in. There should be some indicators in the viewfinder to tell you where in the frame the camera is picking out to auto focus onto. Blurry can only be either out of focus or shake. (It could be both of course!)
Jan 08, 2011 | Canon EOS Rebel G 35mm SLR Camera
I have a Nikon D40x digital camera. The problem began when the screen began showing some type of diagram over the picture I had just taken. The camera then started having difficulty with auto focus. ...
Seems possible that the servo control /main processor control is faulty and will need help from Nikon service , It will be better to get a evaluation for the fault and so we can have a consenses on the fault.
get estimate and decide.
Sep 28, 2010 | Nikon D40x Digital Camera
My photos look blurry not focused. Have tried turning off the auto focus and manually focusing. They are always slightly out of focus, why?
check and make sure you do not have the soft focus turned on. that will make the pictures "soft" in focus or seem out of focus.
Feb 03, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Camera will not focus correctly. when shutter button is pushed half way down the picture goes blurry, and if you take the photo it actually turns out blurry.
If you are taking close up photos, you might have to use the "macro" setting. The auto focus only works down to around 5 or 6 feet I think. I have an earlier model of that camera. I use mine for normal use and also close up for work related photos.
Nov 30, 2009 | Fuji FinePix S5500 Digital Camera
Macro Focusing Problem
try to master reset the camera...press menu...go to set up...highlight reset...go to yes then menu ok again....
Jan 06, 2008 | Samsung Digimax S500 Digital Camera
Photoes are not sharp
Hi, I have never had focus problems with my FX7. I suggest you set the AF mode to 1-area-focusing. This mode is quicker than the 9-area-focusing. To eliminate any possibility that the blurry photos are caused by camera shake, I also suggest placing the camera on a tripod (or setting it down on a flat surface) and using the self-timer to release the shutter. At this point you can also turn off the image stabiliser. A well lit outdoor subject is probably preferable for this test, as low contrast scenes sometimes cause the auto focus problems. If the photos under these conditions are still blurry, then you probably have a defective autofocus. Otherwise...
Sep 04, 2005 | Panasonic Lumix DMC-FX7 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
434 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
