Question about Frigidaire Dishwashers
I have a Frigidaire Aqua Surge with Speed Clean dishwasher. The model # is FDB4315LFCO The serial # is TH64297242. There always is a smell in the dishwasher. Even when I have just washed the dishes, when I open it it smells. Also when there are just a few dishes in and I close the door and reopen it, it smells. I rinse everything very well before I put the dishes in. I have tried cleaning it with a dishwasher cleaner and that didn't help. HELP!!!!!
    President:
  • 1,891 Answers
HELP s on it way . it is or may be a install problem . take a look at the drain and how it connected to the disposal . If where it connects at that point the hose is going down hill then when the disposal is sending the grap down the dishwasher drain line . the dishwasher drain hose should leave the disposal and head up to the under counter edge and then return in a downward way to the dishwasher . this would be called a reverse trap . prvent ing food to go to the dishwasher .. this will prvent the odor .. mm hope this will help feed back pls ..
Posted on Nov 10, 2010
The sprayer that hangs from the top tray fell off. How does it reconnect? Thanks.
Hello wladyka, that's a great question!
Normally, the spray arm would just screw into place on a Frigidaire dishwasher. If you continue to experience issues with the spray arm I would suggest consulting with a professional for further assistance. Hope this helps. -Matt
Oct 18, 2014 | Frigidaire Dishwashers
ICON DISHWASHER
Check and make sure the Air Dry button is not engaged. Check the clean out at the bottom. When you push the top rack in insure it is hitting the opening in the back. Finally purchase some Lemi Shine Machine cleaner for the smell, it's likely you have a some stuff lurking in the screens causing the smell, this made my Icon dishwasher work like new.
Apr 07, 2014 | Electrolux Frigidaire Professional Series...
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
My frigidaire dishwasher model # FDB4315LFCO, is ending the wash cycle with the dishes dripping wet, what might be the problem?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 14, 2011 | Frigidaire Dishwashers
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
I have a dishwasher frigidaire model #FDB4315LFCO When i try to do the dishes the spinarms do not rotate, however the pump is working.Regards, Ard
you may have a water problem. if you dump a bucket of water in the tub after it starts wash cycle and the extra water makes it work. check you line pressure and if thats good replace your water inlet valve.
Feb 25, 2010 | Frigidaire Dishwashers
Doesn't get dishes clean
Remove the lower spray arm, the filter and the volute cover. Check for a foreign objects inside.
If there is nothing wrong then the pump & motor has to be replaced.
- The part number for the pump & motor assembly is AP3160640
Here are the break down diagrams for the Frigidaire dishwasher Model MDB125RGS0
Aug 22, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
151 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
