Question about Hitachi 36CX39B 36" TV
Hi: I have a Hitachi TV set Model 36CX39B that when i push the power button or remote ON, i can hear the usual click indicating that it has turn ON, but in about 3 second before i can see the image, it turn itself back OFF, to repeat this event i have to disconnect the AC cord and plug it back again, but i still can,t see no image. Thank you for your help. Harry Perez
  • 1 more comment
  • hperez4 Nov 09, 2010
    Hi, as a matter of fact i am a licence electritian, and for me this is a challenge, please send me information of this power supply part number and any other part needed to fix this problem, if it,s to expensive then i will decide to get another TV set, at least i give it a try, also i need to know where can i purchase these parts, i am from San Juan Puerto Rico, or maybe you can tell me more or less how much money are we talking about.
    Thank you, Harry Perez
  • hperez4 Nov 10, 2010
    Tim: I appreciate your help, let me know when you find something. Have a nice day.
    Harry
  • hperez4 Nov 12, 2010
    Problem with the Hitachi 36CX39B 36" TV
  • Hitachi Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Nov 12, 2010
    Genius:
  • 1,622 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this help in solving the problem . take care...
Posted on Nov 10, 2010
    President:
  • 2,777 Answers
Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will want to contact a local TV repair person in your area if you want to actually fix this tv. This is actually the most common problem with this type of TV, I see it every day, it just happens - sometimes with new TVs and sometimes it takes many years for it to happen.
If you want to attempt the repair yourself please let me know and I will get you the part number and a place you can purchase it from for what you need. If you want to find a local repair person I can help you with that as well, just reply to my answer here and let me know your zip code. Although with a TV of this age and size it is probably not worth repairing honestly, it will cost as much as a new TV to do the repair.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 09, 2010
  • Tim Grayson
    Tim Grayson Nov 09, 2010
    It will be difficult to find them in Puerto Rico but I can find out if it's possible.
    Tim
  • Tim Grayson
    Tim Grayson Nov 10, 2010
    There appears to be nowhere in Puerto Rico that sells these parts and they are not available online.
    I am sorry about that.
    Tim
My Hitachi 57F710 TV turns off as soon as it turns on?
The model indicated is a DLP which uses a lamp---lamp will not usually cause set right on and then instantly off----takes it 15 seconds or so if lamp has failed.
Also set has led on front that may blink.
If instant it is turned on it goes off----you have a short likely in power supply or elsewhere.
If you have more information or a question press the "make a comment button" on this page.
Mar 26, 2012 | Hitachi 57F710 TV
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
Hitachi model 50UX22B turning off on its own
The TV is in shutdown. The red LED is the shutdown indicator. Check fuse E994. If its open, the TV will need the deflection P.C.B. replaced. Its probably not worth the repair costs. These sets also have had problems with the voltage regulator circuit, requiring replacement of the regulator IC at a more reasonable cost.
michtech
Feb 13, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
Hitachi 50" Projector 50FX18B
Common problem. You can get a repair kit that includes the C707 and E994 + repair instructions from www.TvRepairKits.com
Nov 27, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 36CX39B 36" TV Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
