Question about Dell Inspiron 6400 Notebook
Microphone I used the 6400's built in microphone up to recently and am now not able to do so. I now have to use an external microphone plugged into the mic jack. Would like to know how I might be able to get back to using the internal mic.
  • Jimmy208 Jun 16, 2008
    jomama5509,
    does that mean that the 6400 has an internal microphone?
  • Anonymous Mar 12, 2014
    I used my built in microphone when I purchased it. I sent it in for repairs, a new hard drive and never checked it until recently and could not find the microphone driver. There is an external jack that works but I would like to use the built in mic.
  • 87 Answers
The external mic must be unplugged for it to work and you need to reconfigure the internal mic if it doesn't work... there should be an option for this under start>settings>control panel> audio> microphone
Posted on Jun 16, 2008
How to disable Dell latitude E5500 built in mic so you can connect an external mic?
Just plugging in the external mike into the jack should AUTOMATICALLY disconnect the internal mike.
May 27, 2014 | Audio Players & Recorders
Where is the michrophone on del inspiron 6400?
Unfortunately the Dell Inspiron 6400 is not equipped with a built in microphone.
You can use an external microphone having a 3.5mm jack by connecting it to the microphone connector found on the right side of the laptop.
Hope to have helped you.
May 16, 2011 | Dell Inspiron 6400 Notebook
I Accidentally Disabled the Built-in Microphone on my Toshiba Laptop and I Can't Get It To Work Again?
There is a built-in microphone located beside the built-in web cam. however, if the microphone should stop function, or you want to use an external mic, there is a mic input jack beside the eSata/USB port.
Jan 24, 2011 | Toshiba Satellite L500 Series Notebook
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
Dec 09, 2010 | Dell Inspiron 6400 Notebook
I get a quiet signal when using the mic.
You should use the mic input of your computer.
If it's not there, use a microphone pre-amplifier.
Regards,
Gerard
Feb 17, 2010 | Shure SM57-LC Professional Microphone
MIC
Does she have a microphone plugged in? I dont think the 6400 has a built in mic.
If you're sure your mic works then open the sound mixer (click the speaker icon by the time in the lower right) and click "options" then "properties" and select recording. Click ok. Make sure "microphone" is selected.
Hope this helps!
Dec 25, 2007 | Dell Inspiron 6400 Notebook
Micro phone not working in my DELL Inspiron 6400
There is NO built in microphone with this laptop. You will need to purchase an external microphone and plug it into the mic in socket.
Aug 30, 2007 | Dell Inspiron 6400 Notebook
Canon optura 500
I believe you need a stereo mic. This will have two black rings around the male input. When you plug it into the camera, it will "disable" the built-in mic. I don't believe it will matter if the attenuation is on or off.
Jun 21, 2007 | Canon Optura 500 Mini DV Digital Camcorder
Built-in microphone does seem to work
The only way to really tell if the buit in mic. is bad is to replace the mic or plug another one in the external mic. jack. Also use the input (red and white) RCA jacks and input a signal from a stereo or TV into it and record. If still no sound then its probably Bad capacitors in the sound processor Printed Circuit board. Sorry to be the bearer of bad news but mostly all of older camcorders suffer from this breakdown fault. Good luck
May 21, 2006 | Panasonic Palmcorder PV-GS15 Mini DV...
Dell Inspiron 6400 Notebook Logo
279 people viewed this question
Alun Cox
