Question about Whirlpool EL7ATRR Refrigerator
Not cooling properly toowarm - Whirlpool EL7ATRR Refrigerator
Could it need to be charged
If it has never been opened for service the charge is intact. If the evaporator is not defrosting it won't cool properly. If the compressor is old it won't cool properly. If the thermostat is defective, again it cools improperly.
Aug 29, 2014 | Refrigerators
I have dometic AC 630515.331. I was having a problem with it cooling properly. A service guy checked it out and said the cold control wasnt working properly. Im trying to replace it but I dont see a cold...
When you say, wasn't cooling properly, could you give more details such as, cooling would not shut off, cooling would cut out before trailer was cool, fins/coils were frosting or freezing up. Compressor was kicking out and in too much or any other symptom you notice. All will help with proper diagnosis.
Apr 02, 2013 | Dometic Rooftop RV Air Conditioner
Freezer not working
Check the help links shown below :----Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html-----------Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This willhelp.
Thanks.
Feb 10, 2012 | Maytag MBR2256KES / MBL2256KES
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
It won't get colder than 54 degrees. Why won't it get cold?
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 25, 2011 | Haier HRT02WNCBB (17 cu ft) Compact...
The freezer works properly, but refrig part does not cool to proper temperature. Have checked doors and cleaned behind.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Estate Refrigerators
Fridge not cooling properly. Fan not coming on also when put in super cool mode no fan comes on
then its probably a defective evaporator fan in the evaporator coil section of the freezer,if the fan doesn't run it won't move the cooled air and can't cool anything properly
Jun 22, 2010 | Refrigerators
Fridge area not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hl
Jun 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator is toowarm .
Defrost the freezer
Sep 03, 2009 | Refrigerators
Jenn-Air JCB2389GRS Fridge not cooling properly
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Whirlpool EL7ATRR Refrigerator Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
