Question about McCulloch Electrical Supplies
I have a 5700 11 horse, (brushless). the windinds appear to be good,none burnt or open, but I have no output voltage. Any ideas?
    President:
  • McCulloch Master
  • 1,400 Answers
Some generators have a wiring harness plug. Unplug harness and test for output there. If no output at harness, look for open circuit breakers and test any capacitors in system wiring. Some brushless systems use capacitors to excite armature. If diodes in armature are faulty there will be no output. Generators output two circuits of 115v each when combined will be about 220. If your generator has two 115v plugs each plug will be on a seperate circuit. To verify condition of stator windings, apply low ac voltage (8 - 12v ac less than one amp) to one of the 115v plugs and you should be able to read same voltage on second plug and double the voltage on the 220v plug. Good luck
Posted on Nov 09, 2010
How to fix power horse 4000 generator starts & runs but no power
if its got brushes , then that's were I start to looking , right at them !! if its brushless , then id be looking at voltage regulator board for a reason
Feb 05, 2016 | Electrical Supplies
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
What to check if no power appear nor light when pushing the power button on after pluging in the ac power
Just looking for burns is not enough. You will have to put a meter to every output and make sure it is supplying the proper voltage.
Apr 30, 2014 | Acer AC 711 17" CRT Monitor
York 80 diamond compressor fan is not spinning..how do you tell if the fan motor is bad?
Check capacitor if its good then Ohm the wires to motor if common to start winding or common to run winding is open then motor is out on internal overload ( overheated) cool with water until windings are closed check voltage to motor. If capacitor good windings closed and correct voltage to motor then motor is bad. Also if windind from start to run is open motor is bad. But be sure wires going to motor havent been damaged or cut into. Also if there is any circuit board with fan relay be sure relay is closed and voltage going in and back out to motor.
Aug 23, 2012 | Heating & Cooling
I cannot turn on my tv. when i press on there is a red light blinking at the bottom of the right hand side corner. the red light is blinking 1 slow bit and 2 fast bit and it repeat again and again even...
this case mostly encountered now with in the flat panel television even in other brand, which need thorough troubleshooting. i am hoping that this ideas can help you to fix the problem.first thing to do you will need to open the back cover to access all the board for trouble shooting, there are many things to considered why doesn't turn on but before you go on in trouble shooting let examine first the board look for burnt parts or even PCB foil pattern. and then now turn on your TV then check output voltage at power supply according to its label make sure are all present. if their is a problem with in the output voltage disconnect all the load side then check again, then if you noticed voltage doesn't good unplug the TV then check the filter and the output filter capacitor,use capacitor checker for good reading.aside the parts from power supply you will need to check blown fuse link at control board.
Apr 17, 2011 | Philips Televison & Video
I have an EF4600DE. Everythign looks good but gen unit does not output a voltage.
this is a brushless generator, that means it has a condensor, this is a "normal" fail, see it happen a lo on brushless. Upgrade to a metal can condensor (gets less heat and is a better construction and the problem should be less frequent...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_573a00ba7e399076
Jan 15, 2011 | Yamaha 4500 Watt Electric Start Generator...
No electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Jun 09, 2009 | Porter Cable Electrical Supplies
My 25 horse kohler motor is not charging the battery
Check the output voltage to the battery charge rectifier. It should be around 18 to 30Vac. Anything lower the windings behind the flywheel are shot. If voltage is present, then the battery charge rectifier is shot.
Jul 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Power Supply transformer failed
2 x 5 Watts RMS Stereo
5 watts continuous RMS power output per channel, at 8
ohms, from 120Hz to 15kHz, with no more than 10%
Total Harmonic Distortion (THD).
Jun 04, 2007 | Philips MC-105 CD Shelf System
Electrical Supplies Logo
531 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Mike
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
