Question about Vtech V.Smile TV Learning System
I can't turn on the v tech - Vtech V.Smile TV Learning System
    Problem Solver:
  • 8 Answers
You have to do the steps in the correct order or the system won't work. Start with the TV and Vsmile OFF
step 1) put the cartridge in and make sure it is all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work you can try taking the batteries out or unplug the adapter to let the system clear. Then try the steps again. Good luck!
Posted on Feb 01, 2011
Why won't it start?
You have to have relearn done .
A 10 minutes procedure which requires a Tech 2 and a techline terminal.
A 30 minutes procedure which does not require the use of any tools.
10 Minute Learn Procedure
Tools Required ?€¢
Tech 2
Techline terminal with current SPS (Service Programming System) software
  1. Connect the Tech 2 to the vehicle.
  2. Select "Request Information" under "Service Programming".
  3. Disconnect the Tech 2 from the vehicle and connect it to a techline terminal.
  4. On the techline terminal, select "Theft Module Re-Learn" under "Service Programming".
  5. Disconnect the Tech 2 from the techline terminal and connect it to the vehicle.
  6. Turn ON the ignition, with the engine OFF.
  7. Select "VTD Re-Learn" under "Service Programming".
  8. Attempt to start the engine, then release the key to ON (vehicle will not start).
  9. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF (the vehicle is now ready to relearn the Passlock?"¢ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK).
  10. Turn OFF the ignition, and wait 5 seconds.
  11. Start the engine (the vehicle has now learned the password).
  12. With the Tech 2 (scan tool), clear any DTCs.
30 Minute Learn Procedure
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON (vehicle will not start).
  3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
  4. Turn OFF the ignition, and wait 5 seconds.
  5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes ( the vehicle is now ready to relearn the Passlock?"¢ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
  6. Important: The vehicle learns the Passlock?"¢ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  7. Start the engine (the vehicle has now learned the Passlock?"¢ Sensor Data Code and/or password).
  8. With a scan tool, clear any DTCs if needed (history DTCs will self clear after 100 ignition cycles).
Jan 05, 2016 | 2004 Chevrolet TrailBlazer
How do I turn up volume on HP computer?
If I understand correctly, you had a tech assisting you earlier and he turned off the sound and now you want to turn it back on - is that right?
Check in the lower right corner of your monitor for the speaker icon. If you see a red circle with a line over the speaker it means the tech just muted the sound. Click on the Speaker icon and open the volume control - you will be see the Mute option and just click on it.
If it is more, and I misunderstood your initial description, please respond with the model of your computer, the operating system and what the tech was called in for in the first place.
Regards,
Matt Burns
Jun 01, 2014 | HP Pavilion Computers & Internet
Sylvania 13tv/vcr, has this code on the tv screen (8c1-0.19) when turned on. The TV has a picture,but no sound. The power supply seems to be okay, because when it is turned on it will play for hours,but...
The fact sound works for a moment when power button is held and that you have to unplug to turn off or on means not a circuit problem but that the set is likely in the tech mode or service adjust mode.
I think the best way to resolve this is call Philips (they are Sylvania, Magnavox, and Philips) customer service with the model number and talk to a tech (not the idiots in CS) who will know how to exit this and what the code means--code will tell the tech what is going on.
SD TECH
May 26, 2012 | Sylvania 6313CE 13 in. TV/VCR Combo
Sony wega and i get 4 blinking red lights
4 blinks code shows problem in Vertical Deflection section of TV. Of course it worth to be repaired. If you are not familiar with TV repair then call TV tech to fix it. And if you are tech person, let me know to help you out with tech info.
Jan 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My blinking timer light will not turn off and TV will not turn on... How do I correct this??
You are going to have to call a tech. There are capacitors on the DM board that require replacement. Only qualified tech's should attempt this repair.
Dec 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Access service menu on PROSCAN 42LA45H television
Go to menu, audio, highlight on balance and press 0532. However, the turns the tech menu on(meaning that everytime you hit menu you'll get the tech menu)... I don't know how to turn it off yet.
Sep 17, 2008 | Televison & Video
Nikon Coolpix 5700 - won't turn on
Look in the user manual.It should say something about that if not call tech assistance at 1-800-nikonus. Oh by the way there is a user manual here for ya if you need one in the tech specs of the camera. simple click on the nikon COOLPLEX 5700 DIGITAL AND IT WILL TAKE YOU TO A TECH PAGE WHERE YOU SCROLL DOWN TO FIND IT. Good Luck
Apr 10, 2006 | Nikon Coolpix 5700 Digital Camera
Vtech V.Smile TV Learning System Logo
171 people viewed this question
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
