Question about Refrigerators
I have a kenmore fridge. it is about 6-7 yrs old. all of a sudden it stopped cooling as well as it did prior to summer. the lights inside blew out and the bottom gets about half as cold as it did originally did. the temp is turned up all the way. the freezer still works great. i installed new bulbs but they did not light up. the lighting issue and the cooling problem happened at the same time. please please help.
    Guru:
  • 1,524 Answers
This is a problem with the electronic control. Please furnish the complete model number to identify who was the manufacture as Kenmore does not make their own Appliances.
Posted on Nov 09, 2010
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Fridge and freezer suddenly not working only 1.5 yrs old
I guess the culprit in this case is the compressor.. Do you hear a sound when you are near the refrigirator.. it will be like a fan rotating at a high speed...
Mar 07, 2008 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
Everything thawed out over night. inside fan running but not cooling. 8 yrs old
You have a leak in the sealed refrigerant systyem. A Service man is required or a new fridge. Take your pick.
Oct 07, 2009 | Kenmore Refrigerators
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Light is on but frig stopped cooling
I had a problem with my Viking where the light stayed on in side and was causing havoc with the coling system.
I saved 200.00 doing this.
get a cell phone or a small video camer place it inside the fridge and record to see if the light stays on when the door is closed.
If it does. You may just have a light switch to replace or like I did readjust the push spring that the door hinge hits to active the switch.
Once I did this the light went out and the fridge started cooling normally. the lights will heat up inside the fridge and screw up the thermostat. then the fridge will start to cycle. not good for the compressor.
hope this helped.
good luck
Jun 25, 2008 | Kenmore Refrigerators
Stopped cooling -fisher and paykel fridge
ok you say the compressor sounds right?? there's probably a defective relay overload / start cap combination defective. if you go behind the the fridge and remove a small cover you will see the compressor with power disconnected look for frayed or burnt wires take the compressor cover off and you will see the wires just follow the 3 wires. you can buy a replacement relay/overload capacitor combination all you have to do is wire it any additional questions you can e-mail me at hvac.tech7872pr@gmail.com
have a nice day
May 08, 2008 | Freezers
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
