Question about Home
Bathroom has a chrome radiator with two knobs at the bottom (one on each leg). I turned it off in the summer but now cant turn it on again. I have tried anticlockwise and clockwise and nothing happens. Any ideas??
    Genius:
  • 1,015 Answers
Almost all valves turn to right or clockwies to close and left or counterclockwise to open. You might try spraying some WD-40 on bottom side of knobs.Let it set for a few mins. Tap on top of knobs lightly with a non marring tool such as wooden hammer handle and try to open. If it still wont open you can wrap knob tightly with masking tape or duct tape to protect the finish and use channel lock pliers or pipe wrench to try to open.Don't force it as you could break valve stem. Spray again with WD-40 and repeat above procedure until valve moves freely. Hope this helps. Thanks P:S WD-40 also works well to remove any adhesive left when you remove tape.
Posted on Nov 09, 2010
Stuck defrost mode
On the back of the fridge bottom left or right leg at the rear there should be a white knob, turn this until it starts then leave it , if it happens again you will need to replace the defrost timer.
Jan 08, 2014 | Refrigerators
Tip
How to Open to refill a Reusable Acrylic Pepper & Salt Mill
Hello. This is about opening an acrylic pepper and salt mill or pepper grinder so that you may refill this kitchen utensil. One will usually find that the chrome knob on top of the pepper mill is used to open the pepper mill can be too difficult to open, because one cannot grip the chrome knob on top of the pepper mill to open. I am going to offer three different options for opening a pepper mill:
1) Use a pair of work gloves with specialize dripping material on finger tips. Hold top bulb while turning chrome knob counter clockwise.
2) A small nut wrench with cellophane tape on chrome knob to above marring chrome knob.
3) Get a wrench and a towel. Fit folded towel in jaws of wrench and place towel and open wrench on chrome knob and turn counter clockwise. Practice on a pine dowel to know appropriate pressure to use to avoid marring the chrome knob. If you can replace the chrome smooth knob with a grip friendly knob, if possible.
Finally, do not over tighten knob just finger tight.
on Feb 28, 2017 | Kitchen Appliances - Others
I have a Hyundai i30 and can't reset clock for summer time.
Wot year model is it? For 2012 press and hold the "volume" knob, until the display shows "initial volume". Turn the knob anticlockwise slowly until "clock" is displayed .Press the knob again until the "hr" flashes and turn to adjust. Press again and "min" will flash and turn to adjust. Press the "display" button to exit. Hope this will help
Oct 14, 2013 | Cars & Trucks
My soon lock the bathroom door from the inside and now i cant get into the bathroom. how do i get the door knob off so that i can get inside the bathroom?
The short answer is that you can't get the doorknob off from the outside.
Lock sets and door knobs are purposely made that way to thwart any potential thief with a screwdriver from simply removing the door knob to gain access into our homes and rooms.
What you MAY TRY is to carefully pry loose the door trim in the area of the door knob away from the door jamb. You may have to carefully remove a trim nail in the process.
Then experiment with a flat, thin, solid tool like one of those rounded spatulas used for frosting cakes slipped in between the trim piece and the jamb. Your goal is to try to get the spring latch to retract away from the door's strike plate like James Bond with a credit card. Look at one of your other open doors to visualize how the mechanism works.
This is going to require some patience, but it may save you from having to destroy the door or frame to get into the room.
Jul 27, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
I need to remove a Moen towel bar. It has a tab under the bottom but I dont know what to do
There should be a "set-screw" (a very small screw) at the bottom of base (fat part) of the towel bar. It screws in to hold the fat part of the bar to the "tab". Loosen the screw by turning it counter-clock-wise. Once loose, the towel bar will lift off the tab. Be careful not to lose the screw!
Feb 21, 2011 | Moen YB8086 Mason Towel Ring Bathroom...
Proline Piano Keyboard Stand Assembly Hi, I just bought a Proline piano stand for an electronic keyboard, and the first step on the assembly directions is to move the clutch to the middle position....
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Nov 28, 2010 | Pro Line Proline Pl 400 Double X Braced...
I have a Moen Chateau bathroom faucet (chrome, 1-handle)...I don't quite know which model, but it's an older faucet. When I pull the knob to turn it on, sometimes water leaks down the back of the faucet....
yes it sound's like you need a cartridge.i think the # is 1225,you might also want to invest in a cartridge puller also,moen make's one, and brass craft make's one as well.
Jan 18, 2010 | Plumbing
Small tear drop leak from chrome bathroom radiator, where the joint is, poor weld!
I turned off the radiator and let the leak stop, located the pin head hole, cleaned the tiny area with emery paper, put a spot of flux in the hole then applied a tiny drop of solder. Worked a treat.
Nov 08, 2009 | Google Chrome
Turn up pilot light
The ajustment screw to increase the intensity of the piolet flame is located on the oven gas valve(behind the cntrol knob.
Apr 04, 2009 | General Electric Stove/Oven/Range Chrome...
Corrosion to chrome towel radiator
your completely right mate about most conventional heating systems are open vented unless its a pressurised system..im a plumber and had at least 4 chrome towel rail rads that this has happened with,its a manufacures problem not yours,
send it back
Jan 15, 2009 | Home
Home Logo
256 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
