Question about Kuppersbusch Dishwashers
Model IGV 659.1 Dishwasher When switched on the 'time display' takes longer than 2 minutes to display the planned wash duration. The display works fine to set a delayed start. After cycling the start delay round to 0, or after RESET (buttons A and C pressed) the unit is then 'nudged' into displaying a time. After, at last, a time is displayed the unit works fine.
  • 27 Answers
SOURCE: prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Posted on Jun 25, 2007
joboo1
  • 257 Answers
SOURCE: washing machine won't start. when hit start 0' displayed
Hi, Unplug the unit from AC power for 30 seconds to 1 minute, This should reset it back to the defaults. Good Luck!
Posted on Feb 08, 2009
SOURCE: whirlpool dishwasher adp 5966 6th sense delay start problem
you hold in the start button untill it goes off
Posted on Sep 05, 2009
SOURCE: I have an electrolux edw5505eps dishwasher. The
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Posted on Nov 26, 2009
joe_lishman
  • 192 Answers
SOURCE: AEG Dishwasher 60820 Sensorlogic Delay timer stuck on 1Hr
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
However if the senslogic (pc board) has a program fault, the cost of this board = half the cost of a new washer ......
Posted on Apr 13, 2010
My gaggenau dishwasher GM 954-110 is not working. when i switch it on the display panel shows 2H.
Hello, welcome to FixYa.
The dishwasher you're speaking of (provided it is indeed a Gaggenau GM954) is built by Bosch as you may or may not know.
To address your concern regarding the 2H in the display actually needs to be done in two parts. I'll start with the basic info associated with the 2H displayed.
This can be simply indicating the previous cycle exceeded a 2 hour wash cycle, not necessarily an error and can be attributed with too cold water entering the dishwasher (below the recommended 120F), a longer than normal drain time (due to partial blockages, kink etc. hence longer time needed to complete the cycle) or inproper water circulation during the cycle.
Aside from these issues, it (2H) can also mean the unit has a heating error and if left long enough will show another error of "1" in the display, extremely long wash times, etc.
**The first thing I'd suggest before attempting any repair is running an additional cycle while making sure the water inlet is hot (120F optimum) and the unit does indeed drain fine.
**A fair indication of proper draining is to start a cycle and once washing begins (2-3 minutes) activate the "cancel" and the unit should adequately drain in the 2 minute time allowance.
**To identify proper water circulation, place an empty cup in the upright position in the top rack, start a cycle and inspect the cup after 2-3 minutes and it should be full of water.
After trying and posting the results of these thing's we can move forward with potential heating errors, the cause, and how to remedy them. Let me know what you find and I'll continue to assist you in any manner possible going forward. Good luck.
Regards,
Macmarkus :)
Jun 30, 2011 | Dishwashers
Need user manual.
simple, connect to faucet and be sure unit is positioned to drain into sink. make sure nothing prevents sink from draining. turn on hot water and wash for approximately 10 minutes. since it does not wash very well a longer duration might be in order and or hand washing anything that is not thoroughly washed. It unfortunately will consume lots of water and you need a water pressure from the faucet that is at least 10psi. removing the aerator many times will increase water pressure if needed.
Mar 18, 2011 | Carocelle Industries 19 in. Portable...
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
When the wash cycle takes longer than the time stated on the display, and when the dishes are done, there is about three inches of dirty water in the bottom of the drawer . The repair technician replaced...
A couple of things to confirm first
1. is the second drawer working oK - i am assuming you have a double drawer model?
2. Are you not seeing the wash cycle time on the display? why does the technician want to replace the display (LCD)?
3. Apart from replacing the rotor did the technician try to clean the dishwasher base and pump filter sump?
Please post your comments to help diagnose the cause of dirty water remaining in the dishwasher.
Jan 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool dishwasher GU2400XTP stalls during cycle
Sounds as if you have a faulty timer. These should be covered under warranty. Check you documents for duration of warranty.
Nov 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Sanyo dishwasher model dwm600f
I have same model and it stops with error with 3minutes of cycle left and dishes not washed properly.
Sep 27, 2009 | Danby DDW1805W Designer Series...
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
The digital display is showing S2
try switching off the power for a short time it might reset itself
Jan 01, 2009 | Kuppersbusch K 24 in. IGVS 669.1 Built-in...
Wash cycle
momrules, it could vary depending on the water entering the dishwasher. On a heavy cycle normal time is about 85 minutes not including thermal holds ( pauses that heat the water). On a normal wash, 68 to 75 minutes not including thermal holds. If the water entering the dishwasher is not at least 120 to 140 degrees the dishwasher will pause in cycles to heat the water before advancing. So 120 minutes is not unrealistic. The heaters in the dishwasher are low wattage and will only heat the water approx. 2 degrees every 5 minutes. Catriver.
Nov 30, 2007 | Kenmore 24 in. 17512 Built-in Dishwasher
Dishwashers Logo
133 people viewed this question
Top Kuppersbusch Dishwashers Experts
Craig Butler
Craig Butler
ray gallant
Tom Chichester
Are you a Kuppersbusch Dishwasher Expert? Answer questions, earn points and help others
