Question about Microwave Ovens
My kid put my digital camera in the microwave. Is it completely dead?
    Guru:
  • 1,051 Answers
Probably a total loss. Try a fresh battery and flash card, maybe you'll be lucky.
Posted on Nov 09, 2010
Dead ge microwave
magnetrons work only when the unit is cooking
it smells like an insulation from overheating wire so could be a fuse and failing transformer
take it in for a proper diagnosis and quote but if it is over 2 years old the cost to repair could be more than a replacement unit
May 26, 2017 | GE JVM1790SK Convection/Microwave Oven
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
The microwave oven has completely gone dead Sharp r-1501c. Yesterday the light was on. I went to turn the light off and to put something in the microwave and it lost all power. I've checked the outlet...
It may be the control panel. What ever you do, don't send the control panel to William Miller. He ripped me off, and I have to dispose of my microwave because he never returned my control panel.
If yours has gone dead completely, it's more cost effective just to replace it. I bought an LG to replace mine.
Mar 08, 2011 | Sharp R-1501 Microwave Oven
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Microwave is not responding. It is completely dead. How do I replace the low voltage transformer? and how do I replace the AC fuse? Do you know where I can get the parts from? Thanks so much.
oh dear,,, please dont even try to do this yourself, you could kill yourself,,, and im not kidding,,,
inside your microwave it a very big capacitor that holds 1000's of volts in it,,, its a killer,
have you ever seen a police stun gun working,,
it realy hurts you???
inside your microwave is its very big brother,,
it wont just stun you,,, it could kill you
and a new microwave only costs about £50 now is it realy worth taking that kind of a risk? for £50???
anyhow the parts for yours will cost far more that £50
so why not play it safe and go out and buy a newer one,, your life has got to be worth more than £50
Oct 26, 2009 | Microwave Ovens
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Dead Microwave Oven
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
Jan 13, 2008 | Maytag MMV4205 Microwave Oven
Completely Dead
there is a fuse in the top right hand of the microwave it will burn out when the Capacitor goes bad it will burn it out replace the Capacitor diod and fuse
Jan 05, 2008 | Thermador MBBS Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
