Question about Microsoft Wireless Laser Mouse 5000
I have a Microsoft Laser mouse 5000. The wheel is dirty and sticks. How to I get the mouse apart to clean it?
I have a similar problem but it was not because the wheel was dirty. The vinyl ring on the wheel for some reason becomes abraded after a few months and expands, slowing the wheel down.
I've opened mine up to clean it. It was tricky, and it didn't improve the wheel much.
If you are comfortable with prying apart plastic cases that might snap if you use too much force, here's how to do it.
1. You'll need a small Torx head screw driver. I have a multi-tool called a Teeny Turner made by Picquic. It has multiple philips and torx heads, great for computer parts. (Note: the heads are magnetized, and usually this is a big 'no-no' for computers, so take care to de-magnetize the heads or be cautious about using it on motherboards, etc.)
2. Open the battery compartment gently with your fingernail and remove batteries. There should be a small torx head screw in the battery tray. Remove the screw and gently pull up on the bottom part of the mouse. Now, gently again, pull the bottom part down while pushing it forward. If it doesn't come off easily, stop and examine the bottom part so that you know how the parts are attached. It's at this point where if you aren't careful enough you can break the mouse.
3. If you've gotten the bottom off of the mouse you will be able to get at the mouse wheel. You might need a pair of needle nose pliers at this point because you will have to gently pry off the white plastic that covers the wheel. Again, examine it in order to understand how it's attached to the base of the wheel assembly. You'll have to hold down the black bottom part under the wheel and pry the white cover upwards. It took me 15 minutes to do it without breaking the assembly.
4. Now for the aggravating part: it's neigh impossible to remove the wheel out of the wheel assembly. It's at this point that I simply used lint-free cotton swaps and a degreaser, and cleaned the wheel by hand.
Like I wrote, cleaning mine only helped a little. If I were to do it again, it'd get a moto-tool and shave off some of the interior of the white plastic cover that surrounds the wheel.
Good luck.
Posted on Nov 28, 2010
The left click button on my mouse does not work. Everything else on the mouse works! I tried resync it ..but it still does not work! I am on a vista-32g
Same issue. I took it apart, cleaned it, and reassembled. No luck. Shelled out 25 bucks for a new one and pitched the broke one.
Sep 07, 2010 | Microsoft Wireless Laser Mouse 5000
Can not get Microsoft 5000 wireless mouse to Pan in AutoCAd 09
Do you use the "hold middle click" way of panning? If so, check that in the Windows Ctrl Panel under Mouse, that the scroll wheel is set for middle click. Why this is not default on all new mice I do not know!
Aug 09, 2010 | Microsoft Wireless Laser Mouse 5000
Microsoft laser desktop 5000 vs Windows 7
The software might not be compatible. but for you to use the wireless keyboard and mouse you don't need a software just plug the wireless adapter and sync the keyboard and mouse . it will start working
Jan 17, 2010 | Microsoft Wireless Laser Desktop 6000...
The scroll button on my mouse is stuck, will not turn.
If the scroll button is sticky, take a q-tip and clean the wheel off on the outside and as much in the inside as possible. Dampen the q-tip with water.
If that doesnt' work, look for screws that hold the mouse together, unscrew the screws and take the mouse apart. At that point clean the scroll button and then put everything back together.
If the mouse still doesn't work properly then at that point, you'll need to get a new mouse.
Jan 01, 2010 | Microsoft Wireless Laser Mouse 5000
My wireless mouse 5000 is not responding yet the keyboard is. So, what is the problem?
Replace the batteries, look under the mouse you should see a removable cover, the batteries should be in there.
Dec 19, 2009 | Microsoft Wireless Laser Mouse 5000
How do i clean a microsoft 5000 laser mouse?
You can clean your laser mouse using an alchohol. Just pour a little achohol in a cotton and wipe it all around the mouse. If you want also clean the inside of the mouse then you must a screw driver to open it. Once open, you need a brush and brush the mouse board inside. You can also use a blower to get rid of the dust inside. Hope this could help. Please don't forget to rate me..:-) Thanks..
Nov 05, 2009 | Microsoft Wireless Laser Mouse 5000
My wireless laser mouse microsoft 5000 quit clicking on the left button
Normal 0 Go to Control Panel and click on the Mouse icon.
Then select the Mouse button you need to program.
Hope this helps. Bud
Jan 08, 2009 | Microsoft Wireless Laser Mouse 5000
Microsoft notebook mouse 5000 Wheel scroll stopped
Fixing the wheel/scroll malfunction was as simple as a reboot. I usually shut down in hibernate. Apparently the system needed a complete reboot to reset.
Thank you for following up.
Nov 22, 2008 | Microsoft Wireless Laser Mouse 5000
Microsoft Wireless Laser Mouse 5000 Logo
522 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
