Question about Amana Refrigerators
Ice melting - temperature rising - Amana Refrigerators
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 09, 2010
Frigidaire icemaker not working
Hello Guest,
Thank you for your posted inquiry. Typically when an ice maker does not function properly there are a few things you can check before contacting a professional. First, I would check to see if your water dispenser is correctly operating. Next, check when the last time you changed the water filter was. This could clog some of the water lines and forced air in this tubing which can create problems. Finally I would check the temperature in the freezer compartment. Is it higher than normal? Do you notice anything thawing out or melting perhaps? This indicates the temperature is rising. When the temperature rises the ice maker will not operate properly at all and shut itself down for safety reasons. You can always look to see if your ice maker has a shut off arm or switch. Reset the ice maker if it does and wait up to 24 hours for more ice to be produced.
Otherwise, if nothing proves to be successful I would absolutely contact a professional for a full diagnosis on the unit. Hope this helps!
Apr 01, 2013 | Frigidaire Refrigerators
I have a Frigidaire upright LFFU1465 and it is on but not blowing cold air.
If the condenser is clean and the temperature rising, the freezer is short of gas
Apr 13, 2012 | Freezers
Our ice is coming out in one big unusable clump.
Ice is melting due to a sealed system problem causing the freezer to rise in temperature.
This must be attended to by an EPA "Certified" Technician.
Jul 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
My 5-year old KSC9251 side by side KitchenAid ice maker will quit delivering ice for no obvious reason, except the temperature in the freezer will rise a few degrees. A change in the recommended settings...
There is actually a small heater in the ice-cube tray. The heater melts the surface of the ice to allow the cubes to eject without too much effort.
My guess is that your heater cable may be unplugged or not plugged tightly. If not, your heater may be burning out.
Usually $50 to $75 for that section of the ice maker if you can get the parts and do it yourself.
Mar 30, 2010 | Refrigerators
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Sep 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Honeywell CT3600-AC not working
could be froze up if it is turn it off to melt ice clean unit could be low on freon or bad blower motor
Jun 17, 2009 | Honeywell CT3600 7 Day Electronic...
ELEVATING TEMPERATURE INSIDE FREEZER
the capasiter on the back of the fridge is blown
Aug 27, 2008 | Refrigerators
Not cooling but everything seems to be on
remove back panel inside freezer and evaporator pipework will be exposed.
if this is heavily iced up, airflow will be impeded and hence rise in temperature
disconnect from mains and melt ice off carefully with a hairdryer then switch back on
you probably have a fault with the defrost system if this is the case - get back to me
Jul 15, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
