On the mits wd 825, 725 625 and 525 chassis I think its the v26, is the only way to get the blinking timer light problem resolved is sending the chassis to be rebuilt?
  • Patrick McAlexander Nov 09, 2010
    I have 2 WD52825 tvs doing the same thing
    Just blinking timer light like many others. Mits says send it in for rebuild but they charge an arm and a leg. Lamp has been changed but not ballast. Just wondering if there is another fix for this "blinking timer light of death" other than sending in the chassis.
  • 5,138 Answers
What is the Model number that is printed on back of TV? Then I will be able to help you with your problem? This is very important to know the correct Model # For Finding the correct Parts.
Posted on Nov 09, 2010
  • 1 more comment
  • ladywinn
    ladywinn Nov 09, 2010
    What seems to be the main problem you are needing help with?
  • ladywinn
    Has the Lamp or Ballast board ever been replace and if so when?
  • ladywinn
    Encompass Parts Distribution List 680 parts for this TV.
    Call PTS and ask them what they charge to rebuilt board. 1-800-844-7871
    Mits,has big problem with alot of bad capacitors over 52caps on power supply board
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Timer light is blinking and won't come on
Thats a very common problem with that model which is the V26 chassis. You can get the V26 Chassis DLP DM ? Power repair kit from www.tvrepairworld.com which has the replacement caps known to fail on the DM and Power boards. The kit also has the CD with step by step repair instructions.
Aug 06, 2012 | Mitsubishi WD-62725 62" Rear Projection...
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Tv will not reset....the timer light continues to blink even after I have tried to reset the TV several times
Thats usually caused by failed capacitors on the DM and the Power boards most of the time. Its very famous for your model which is the V26 chassis. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps for both boards and the CD with detailed repair instructions.
Aug 13, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Timer led blinking@ 12 blinks then pause and then again , on mitsubishi wd62825g
This is the kiss of death on the V26 chassis. Your power supply has reached it end. This boards for this TV are no longer available from Mits. The chassis can be sent in for complete rebuild for a total of around $750 or you can call Mits consumer relations dept. and discuss some sort of concession for a new set. I would recommend the latter. Good luck
Bill W
integrityhomeworx.com
Mar 08, 2011 | Televison & Video
I have a constant green blinking light under Timer, I have pressede the reset button numerous times and I have also unplugged the tv. What next? or what do you think?
Thats usually caused by the failed capacitors on the DM and the Power boards. You can get the V26 Chassis DM and Power repair kit from www.tvrpairworld.com which also contains the instructions.
Jul 03, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light of Death on Mits WD 52525
The V26 DM repair kit will usually repair that issue. You can get the kit at www.tvrepairworld.com the kit contains the replacement capacitors and the CD with Instructions.
Nov 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light is blinking green and tv wont turn on
The V26 Chassis DM repair kit from www.tvrepairworld.com should repair that issue. The kit also contains the cd with detailed instructions
Nov 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
May 23, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Blinking green light under 'Timer' flashes there is no picture
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Feb 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
