Question about Kenwood VR-407 Receiver
Whenever I play anything...whenever the bass drum comes in, the speakers create a major major popping sound with every bass note.
  • christoph75692 Nov 10, 2010
    None of the above sir.
    None of the above Sir. It happens in both speakers at the same time, in tune with the bass drum. Does it at any volume.
It could be a number of things, hopefully they are not blown out. Click on the link below to read more:
http://www.ehow.com/about_6586867_do-speakers-make-popping-sound_.html
Posted on Nov 11, 2010
    Novelist:
  • 87 Answers
There are 2 possible issues here. First is that the amp is running out of power. If you are at high volume settings, consider trying it at a lower volume. Second is that the bass speaker is messed up. Messed up is a technical term for a multitude of possible issues. This would likely only show up on one side or the other (left/right) assuming you don't have a subwoofer in the mix.
Posted on Nov 10, 2010
  • vtwin113 Nov 12, 2010
    OK - both speakers at any volume. I'm voting for a serious power supply issue within the receiver. That's probably not a do it yourself repair. If you can find another speaker to try out, that would give you a certain indication that the issue is in the amp or not.
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
Jan 04, 2013 | Alesis DM6 Electronic Drum Set
Hi my creature 3 speakers were used at a party and the subwoofer dropped a couple times off about a 2 feet high table. now whenever i try to play music from my computer theres a loud buzzing noise in the...
A wire inside the cable has probably come loose, unless you (or a friend) have decent soldering skills to just replace the wire form the audio controller (most likely spot to have problems) to the PC they are probably just trash.
May 17, 2011 | JBL Creature III 2 Speakers
Watching television or a film my Eltax Atomic a-8.2 subwoofer cuts in and out whenever it feels like it! you can hear it click then the bass cicks in then, even when you know there should be some bass...
most active subbs are desinged to shut off untill they are needed ( extreem bass injection) then they come on try setting your sensitivity to low or off
Jun 18, 2010 | Eltax Atomic A-8.2 Subwoofer
Dell Latitude D830 instant off whenever loud sound played
Either that or the battery is near the end of its life and when a big spike in current is needed it fails so the voltage drops and the processor chokes, instantly shutting it down.
Jun 01, 2010 | Dell Latitude D830 Notebook
Bass sound coming out whenever i move the right speaker
seems like one of the wires is loose either inside the speaker or in the cable leading to it.
best chance is to open up the right speaker ( involvs damage to the plastic , since atp3 speakers are glued and practically unopenable with out breaking)
and then trying to play with the wires `till you find the sourse of the problem.
as soon as you know where the probles is , i`m sure its gonna be easy to fix, again , the hard part is to take this speaker apart.
good luck
Sep 08, 2009 | Altec Lansing ATP 3W Computer Speakers
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Great sound, no voices
Mine was the center speaker wire was not properly seating in the speaker. This is where all the sound for the voices come out. I thought it was something major. try checking them again if you haven't already.
Nov 04, 2008 | JVC TH-M505 System
Noise from speakers when playing basses
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Jul 28, 2008 | Audio Players & Recorders
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
Kenwood VR-407 Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
