Question about LG RZ-37LZ30 37 in. LCD Television
My stationary computer starts up all normal and like but my screen is blue and has a message saying PC-RGB NO SIGNAL i restart and restart and restart my computer try to push all the buttons the ussual BUT nothing helps!
Benimur
  • 6966 Answers
SOURCE: Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Posted on Apr 14, 2007
SOURCE: Trying to connect PC
after cunnecting did you switch to monitor on pc
Posted on Nov 13, 2007
  • 96 Answers
SOURCE: No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Posted on Feb 10, 2009
SOURCE: tv says no signal after hooking up computer to it
I had same problem, adjust settings on your computer desktop resolution to 800x600 solved my problem right away, computer resolution is probably too high. Hope this helps!
Posted on Jun 09, 2009
SOURCE: pc to tv
buy a video cable and a sond cable and connect them to the back where is says rgb pc.then tao input - rgb pc.
Posted on Jun 28, 2009
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
'No rgb signal' to second (old) monitor
try restarting the pc in safe mode
uninstall the graphic driver restart the pc and again restart the pc
this is problem of screen resolution
Apr 10, 2014 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
Blue Screen Error
What were you doing ,just prior to the shut down? Take a look at this:http://pcsupport.about.com/od/fixtheproblem/ht/stoperrors.htm
Dec 07, 2012 | HP ProBook 4540s Notebook PC ENERGY STAR
When i connect the projector to my computer, all it says is no input selected. i need help with this IMMEDIATELY!!!
make sure the computer has the output screen signal enabled on the external rgb connector. you can confirm this by connecting an external lcd monitor to the pc. swap the pc vga output to the projector.
then make sure the vga/rgb input source is selected on the projector.
also select the lowest resolution on the pc to start with. when a picture appears on the projector, then increase the pc screen resolution until it says it's not able to show it, and back off to the last setting that worked
Apr 13, 2011 | ASK Proxima Office Equipment & Supplies
Cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Feb 19, 2010 | Acer Computers & Internet
RGB No Signal Message
First you need to check the cable at both ends, inside and out. Make sure it is plugged in, to the proper connector and that there aren't any bents pins. Now put this monitor on another computer, a laptop will do. Does it come on now? If so then your video card in your machine is bad. If still bad then the monitor has lost it's signal input. This will have to be repaired by a pro. I repair these all the time and it's not as expensive as you might think.
May 30, 2009 | Gateway FPD1975W 19" LCD Monitor
TV will not stay on.
MIne did this at first. Unplug from source for 2-3 minutes, then try again to turn on. Should come up then.
Apr 03, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
LG RZ-37LZ30 37 in. LCD Television Logo
Computer Repairing
Computer Repairing
