Question about Ovens
I can not use the oven. I got a display " sabbath", but the key path are inactive. What can I do.?
  • 441 Answers
The oven is in sabbath mode which wont let you do anything, unplugg it for 1/2 hour or flip off the breaker for a 1/2 hour. This should reset it for ya!
Posted on Nov 09, 2010
Tappan built in oven display not working
Find the owners manual and check to see if it has a sabbath day mode if not you will need a oven control which has the display assembly
Mar 17, 2013 | Tappan Ovens
The display says "SAB" on
it's locked in sabbath mode for jewish holidays,hold the clock pad in for 3 to 5 seconds to take it out
Sep 18, 2011 | Ovens
What does 5ab mean on the oven?
Some ranges with a lot of features have a Sabbath mode, hence the letters Sab in the display although it looks like 5ab. Check your owners manual and it should tell you how to turn off the Sabbath mode. If you don't have a manual Google your model number and Sabbath mode.
Aug 28, 2011 | Ovens
Control panel is stuck on 5Ab
Sabbath Mode.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
May 16, 2011 | Ovens
My oven display has "sABBATH" written on the
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
Apr 24, 2011 | Maytag 24" Built-In Single Electric Wall...
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
ARROW pad.
"3".
shut-off.
Other Displays:
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
ARROW pad.
"3".
shut-off.
Thanks for using Fixya, let me know.
Jan 06, 2011 | Maytag Ovens
Jenn-Air gas wall oven some how got stuck in ''Sabbath'' mode and unable to reset.
ok it happens / so to enable the Sabbath mode 1 open the door. 2 press cancel/off. 3 press the number pads 7&8 and 9 , in that order. 4 press Number pad 6 . 5 press start. "sab and on" will appear on the display ..( now to disable the sabbath mode .}. ( repeat the steps above to disable the Sabbath mode. " Sab and off" will appear on the display .. there now that wasn't too tuff was it .. mm hope this helped ..
Jul 15, 2010 | Jenn-Air Ovens
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
Jun 16, 2009 | Maytag MEW6527DDS Electric Single Oven
Dacor ECD230 Sabbath Mode
You don't need to do anything special.
Quoting from Daco.com FAQ
"In our ovens, the cooling and convection fans do not turn off when the oven door opens. The lights also do not turn on. There is no timed shutoff on our ovens, either, meaning that once they are turned on, they will stay on until you manually turn them off. Both of these would be considered violations. Our ovens do not have a special Sabbath button because our ovens already adhere to the laws. When the oven door is opened, there are no changes to the control panel, which would also be a violation. It is best to wait for the small "On" light with the circle around it to go on before opening the oven door, though. This light indicates that the element has gone on, as the oven cycles on and off to maintain the selected temperature. Opening the oven door without this light going on may trigger the element to go on, which can be a violation."
Mar 25, 2008 | Dacor ECD230 Epicure Stainless Steel...
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
