Question about Intel DG45ID Motherboard
To give background I have DG45ID mother board, and a ATI 5570 video card. My computer works with no problems until it goes to sleep for more than I few minutes. When I try to wake it up after it has been asleep, I move the mouse or touch the keyboard and the computer wake up but my monitor says no signal. At the same time the signal to my keyboard and mouse are also lost. I've set my power button for hibernation, if I press the button after everything else stops working, it resumes windows and everything is working normally again. Thanks
Try updating all the drivers. Mainly the chipset and the video card drivers. If you have a wireless card, update it too.
Also make sure that the onboard video card is disabled in the setup-
Posted on Nov 09, 2010
D33025 drivers
D33025 is not the mother board model number it represents regulatory or industry specification markings and cannot be used to identify your board.
Give other marking on the board you can find such as DG41TY, D865GVHZ, D945GCLF2, DG45ID
Apr 30, 2012 | Intel Computers & Internet
Does hd 5570 1 gb ddr3 support my intel board dg31pr board? tnx
This motherboard will support ATI HD 5570.Because it has one PCI Express x16 slot.
Thanks for using FixYa.
Jun 12, 2011 | Sapphire 100293-2GL RADEON HD 5570 2GB...
My monitor goes to sleep immediatly after I turn it on. I have check all the cables.
I would take you computer to a computer store to have it hooked up. this will alow you to see if you video card is bad. You mother board could also be bad, so video card are mounted directly to the mother boards.
Most likely is not monitior but video card
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 09, 2009 | HP L1925 19" LCD Monitor
I just installed SIMS 3, and it keeps freezing up and crashing. Is my ATI Radeon X600 the problem?
The card is most likely NOt the problem, best thing to do is upgrade the Graphics drivers and other drivers... If that doesnt work...
Check to make sure the Ram is sufficient,
I believe it would be the problem if its a older card, and Sims 3 is a high Polygon game. and Alot of radeon cards Get old quick.. if You really want to play sims 3 Upgrade your Video Card If your running a Crossfire Mother board (Ati only) Buy one of the new Ati cards 4890 i believe is the newest one, Its a great card
If your running a Full compatibility board buy one of the new Nvidia's But before you buy make sure your Computer Supports it :)
Jun 04, 2009 | ATI RADEON 9200, (128 MB) AGP Graphic Card
Can we use a internal graphic card in a mother board in another m
Yes if it has the port for the graphics card it will work with the onboard graphics card just make sure then that your video output is plugged into the ATI radeon and not the onboard..or it will not work correctly. if you have anymore questions just let me know and i will answer them asap.
Apr 10, 2009 | Computers & Internet
Video card keeps making monitor go off
I had a very similar problem. I fixed it by updating to the latest drivers for my video card. You will find the latest video drivers for your card here.
Enjoy :)
Mar 21, 2009 | ATI RADEON Graphic Card
Video card in Dell Inspiron
hi steve, either the video ati 7500 is not compatible with your motherboard, which is very unlikely... its a big possibility that your video card is defective
Feb 09, 2009 | ATI RADEON 7500, PCI Video Card
Display problem ...Graphic card or screen
that is graphic problem, you might not properly set the correct resolution, or the cord might loose connection. try to remve the video card clean it then re install
Oct 04, 2008 | Computers & Internet
Hp pavilion zd8000 ati mobility radeon x600 128 mb
A bit late over a year has passed.........
I have a smilar problem, with the ATI enabled the laptop black screens on startup.
If you disable the ATI x600 in Device Manager (using safe mode) the laptop works fine as the ATI is not being used.
Solution is to replace the ATI x600, which unfortunately is a specialist job as this is soldered directly onto the motherboard. Or replace the motherboard.
I have located a company in Manchester (called CRM) that repairs HP computers, and they can repair/replace the ATI for around £175, or replace the motherboard for about £250. Replacing the board gives you a 12months warranty. add VAT to those figures. There phone number is 01618881232, I have found them to be very helpful.
Mar 24, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Hp z558
This sounds like a poor put together pc. If the DVD drive does not eject then either the dvd is faulty or the IDE cable and/or IDE1 connector on motherboard is not installed, try ejecting through my computer(right click on drive then Eject), if this works the button is faulty. The same goes for the TV Tuner card, again possibly a corrupt or non installed driver, try re installing mother board drivers and card drivers. This really needs to be returned as the pc is not fit for it's use.
Feb 19, 2007 | HP z558 (EG652AA) PC Desktop
Intel DG45ID  Motherboard Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
