Question about Dell PowerEdge 1800 Server
Poweredge 1800 trouble shooting support
My cooling fan  does not seem to shut off now. we had a power outage the nigh befor and the system was runnin when the outage occured. but we have a serge protector and batterie back up for the system. restart and shut down dont seem to have any affect. cooling fan continues to run on high
  • 174 Answers
Upgrade your bios or set temperture high on the management software
Posted on Jul 02, 2008
Cooling fans dont work
If the fans don't turn when you first put power to the system, most likely the fans need to be replaced.
Sep 13, 2014 | Dell (6F858) Cooling Fan
Trouble shoot cooling fan on honda vtx mc
From the VTX 1800. Can't find the ctx mc.
there are 15 pages alone for the cooling system.
Jul 24, 2014 | Motorcycles
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
Can I use a 650W ATX power supply to replace DELL powerEdge 1800 650W power supply (PS-5621-1)?
so long as it fits and the cables connect fine you should be able to use the new power supply
Nov 19, 2010 | Dell PowerEdge 1800 Server
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Dell PE1800 psu wont swith off...Computer powers down but psu fan continues to run. Have to pull the power plug to shut it down.
Sounds like the PSU is overheating. Some PSU's are designed to keep the fan running to cool it down even after system shut down. I would let the fan run after shutdown to see how long it takes to shut itself off. If there are no environmental issues tat are causing overheating you might want to consider replacing the PSU.
Sep 13, 2009 | Dell PowerEdge 1800 Server
Flashing redlight on the front
Yes. Here are some things that could be an issue:
a problem with power supplies, fans, system temperature, or SCSI hard drives.
Install the Dell Open Manager software to run diagnostic. It will tell you what needs to be fixed.
Apr 29, 2009 | Dell PowerEdge 1800 Server
How i turn off a fan from motherboard
The fans that are plugged into the motherboard are usually powered by the motherboard. To turn them off, simply unplug them as there is always a power flow going through the motherboard and even more to power the fans when the system is running. I would recommend keeping the fan in if possible to help with cooling your PowerEdge 1400 server, but if it must be removed, simply power your server down, and unplug the fan. Make sure your server is powered off before doing this, as you don't want to short anything out or cause a spark.
Mar 13, 2009 | Dell PowerEdge 1400...
Dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Mar 17, 2008 | Dell PowerEdge 1800 Server
Server is giving beep with red light on.
Hi Mirwais,
The beeping problem could be an indication of a few issues. One of which could be that the hard drive is overheating and when you remove it for those ten or twenty minutes, the drive cools and the problem disappears until the next time it heats up. You should open the machine and do a cleaning with a vaccuum. Heavy dust accumulation within the box can be a cause of poor air circulation. Also be sure to vac out the power supply fan and check that the fan is actual working to cool the system.
Also the beeping sound could be a sign that the processor is overheating, so be sure that area around the processor is cleared of dust and the processor is getting proper circulation. Have you experienced any system freezes. It YES then I would definitely look closely at the processor.
Nov 06, 2007 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800 Server Logo
336 people viewed this question
Alun Cox
