Question about Panasonic KX-MB271 All-In-One Laser Printer
What is the "call service 3" error and how can I
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KX-MB271-_E
Posted on Nov 09, 2010
How do I clear the general message: See your printer documentation for information about clearing the error?
Give this a try
***Manually clear the print queue***
1) Open the "Services" panel. The easiest way to do this is click "Start" and type "Services.msc" (no quotes) in the search box.
2) Scroll down the list of services to find and select "Print Spooler". Click "Stop" in the left panel.
3) Open Windows Explorer ("Computer" in the Start menu). Navigate to the spooler directory (typically "C:\Windows\System32\spool\PRINTERS") .
4) Delete the files in the directory.
5) Go back to the Services panel and click "Start".
Dec 13, 2015 | Epson Stylus Photo 925 InkJet Printer
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
The CE code is showing on screen
Communication error
If communication between the ignition board and the display board is not established
within 3 s of power-up an error will be displayed. After communication is
established, if it is lost for 30 s, the error will be displayed. The error code will
be cleared upon a valid data exchange between boards.
May 18, 2012 | Hayward H-series Electronic Gas Pool...
Need to pay for 3 items on ebay, 1 payment came out of my papal account, Now im trying to pay with my registered card, and i get a message that says "i need to update my paypal account and this must...
I would suggest calling customer service, the number is 1-402-935-2050
if you do need to update the account they can do it for you over the phone
also it's a good idea when you get a error message to clear the internet cookies off your computer when errors come up, & see if that solves the problem & if not call paypal customer service
Sep 05, 2011 | PayPal Accounts
I have the wrench on in the color red and an error code of SC541. Copier does not allow copying in this mode. I tried "Clearmode" button, then numbers 1,0,7. Then I held down the...
Yes, this is a fuser error code. You're doing all right .
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And that´s it...
It is true that this code can appear more on cold days but it is already the second time it appears. You must have thermistors making bad reading. This may be caused by crusted toner or tired. You can also have the roller fusion whith toner crust. In any case I advise you to call technical intervention.
Do the procedure that i told you to be able to work with the machine.
Jan 22, 2011 | Ricoh Aficio 450 Copier
Cames on screen SC548
Hi.
I quote from manual:
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -
Fusing unit is not installed
Poor fusing unit connection
To reset try going in service mode and performing a reset.
To open service mode press [All Clear(yellow)] ,[1],[0],[7],[Clear(orange)]and keep holding down the clear button for about ten seconds.
When service mode starts, go to Copier Options , then choose mode 5, and option 810. Execute by pressing 1 and ok.
Do not change anything else in service mode, or you can cause more troubles.
If that does not clear the error , then there is a faulty part, in that case call service at the number listed in the user manual.
Jan 09, 2011 | Ricoh Aficio 1035 Copier
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
I am getting an error message "H-4" on my copier. Xerox says that they do not service these anymore. ???
Well if you depend on Xerox service, then you have a problem. They are getting out of the service business. But there are tons of Xerox dealer service and independand service that service that product. But you do NOT need a service call. Do this reset and it will correct your problem. This WILL work.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps several times
Oct 21, 2008 | Xerox WorkCentre XD120f Copier
Panasonic KX-MB271 All-In-One Laser Printer Logo
869 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
