Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore wall oven door will not unlock after cleaning cycle.
  • Kenmore Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Nov 09, 2010
  • 100 Answers
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
  • 6 Answers
SOURCE: oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Posted on Jan 26, 2008
SOURCE: Oven locked so I can't shut door/operate oven
I Idon"t have one. I have the same problem
Posted on Nov 19, 2008
  • 29 Answers
SOURCE: My Kenmore Oven door won't unlock
Try throwing the electrical breaker off and then on to see if it will reset. If not you could put it through another cycle to see if its a jammed armature. However either the door lock motor armature is jammed or the motor is the problem or the solid state did not recognize the cycle was over. If you open the breakers and remove the covers to access the mounting screws you can work the unit out of the wall. Be sure to place some heavy towel or card board on the ground to keep from damaging the floor. Watch placement of your hands and depending on your fittness level you may need a hand pulling and replacing the unit. Test the electrical supply to ensure that its not energized. Then try disengaging the lock armature. IF YOU OPT TO REMOVE THE LOCK THEN THE UNIT SHOULD NOT BE USED IN THE CLEANING CYCLE, EVEN THOUGH THE UNIT SHOULD NOT FUNCTION WITH THE LOCK DISENGAGED, YOU NEVER KNOW ABOUT ELECTRONICS AND IF IT RAN IN THE CLEANING CYCLE SOMEOEN COULD OPEN IT AND GET BADLY BURNED. SO DONT DO IT. You should be able to order the parts needed on line at this website. http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears Best o Luck :?) DRRXR
Posted on Feb 15, 2009
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
How do I unlock the oven door when it won't unlock after cleaning?
Hello friend, thank you for your post!
Based off the information you have provided the door on your Frigidaire wall oven is not unlocking. Performing a reset on your oven can trigger the door latch to unlock, in order to reset your oven you would need to disconnect power from it for roughly ten minutes. If this does not resolve your issue with your oven you can also hold down the clear or cancel button for 10 to 15 seconds.
Another step you can attempt is to perform a self-clean cycle and before the cycle starts cancel it and that can trick your oven into unlocking. If these troubleshooting steps do not help correct the problem it could be a faulty door latch or control panel. I hope this information has been helpful. -Matt
Mar 14, 2015 | Frigidaire 30 Single Electric Wall Oven,...
How do i unlock after self cleaning my kenmore elite electric slide in 30"
Hello,Give it time for the oven to cool if it has just completed the clean cycle. The door is not to unlock if the oven is still too hot. If the oven is cool and the door will not unlock,program and start another clean cycle and after about two minutes press cancel/clear/stop and wait for another minutes to see if the door will unlock.If the door doesn't unlock i recommend calling a service technician to diagnose and repair your range.
Thanks
May 29, 2010 | Kenmore Ovens
Oven door will not unlock
Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
MIchael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Cannot unlock self-cleaning oven
I ran the cleaning cycle again, and it the door opened without difficulty.
Sep 13, 2009 | Kenmore Ovens
Feb 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
I cant get my oven to unlock its door
you will needto let it go through the cleaning process to comeplete the cycle for the door to unlock,thats about the only way its going to unlock now
Dec 06, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door won't open after self cleaning
it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
Jan 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
174 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
