Question about Amana ARGS7650SS Gas Kitchen Range
Smell gas when oven lit - Amana ARGS7650SS Gas Kitchen Range
  • Amana Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 09, 2010
aborcass
  • 2651 Answers
SOURCE: Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Posted on Feb 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Burners work,Broiler works but oven does not preheat
If everything works on your range, but the oven, the most likely culprit is the igniter for the BAKE manifold. What is confusing me, though is the statement in your question where you say the "oven will light up, but never get hot". Yet, you say the oven does not ignite. Can you clarify this? In some ovens the BAKE and BROIL manifolds BOTH light when preheating, to reduce the warm up time. Once the desired temperature is reached the manifold not in use, will shut off.
In any case, on a gas range, the burners for the BAKE and BROIL manifolds use an electric glow bar type igniter. There's a separate igniter for EACH burner. When you make a bake or broil selection on your oven control, the respective igniter begins to glow. After the igniter reaches a certain current potential, the gas safety valve is opened, gas flows to the manifold, and voila! You have ignition. It can take as long as 90 seconds for the burner to ignite. What can happen over time, is the igniter becomes weak or fails. If the igniter becomes weak, it will still glow, but it never reaches the desired current potential to open the gas safety valve. The result: you end up with an igniter glowing with no ignition. And, if you're like me, you're left scratching your head wondering why the thing isn't working when it "looks" like it is. You can easily tell if the igniter is working by opening your oven door and selecting bake. Watch the oven pan in the bottom of the oven. You should see an orange glow coming from under it. It here's no glow at all, the igniter has probably failed. If there IS a glow, a current reading will tell if it's within tolerance. The following link explains more on these igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter is a common fail item as it gets used more frequently than the broil function. On your range both igniters are interchangeable. You can purchase replacements on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. The part number is WB2X9154. Shop all three sites for the best price.
I hope this helps you. If my assessment of your symptoms is wrong, or if you need further assistance, please let me know.
Posted on Jan 16, 2009
SOURCE: Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Posted on Mar 30, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Large oven does not light but glow bar is lit.
You need a new thermal probe.
Posted on Jun 26, 2009
  • 744 Answers
SOURCE: Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Posted on Jan 13, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
This just happened over night the oven is on but there is a bad gas smell when it is in use. There is a hissing noise too.this oven runs on propane
When the burner is burning, are both sides of the burner lit and is it lit all the way down the burner? If it is and you are still smelling gas you should not use the oven until you have it serviced, so you do not have an explosion. Propane is heavier than air, and will settle in low areas, so smell low by the floor around the oven before you light it to make sure you don't have a leak first. To be safe until then, close the shutoff valve on the gas line at the appliance until you get it looked at and fixed. Douglas
Jul 02, 2010 | Ovens
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
Put in a new ignigter for the oven. the ignigiter lits up but the oven doesnt light its a GE gas oven. the top range is fine and the broiler works fine
If you don't hear/smell gas when the ignitor is lit, then the gas valve is stuck. Tap on the gas valve (I usually use my 10" Knipex pliers). Be careful not to touch any electrical contacts and not to cause gas leaks. If not sure - use something made of plastic. ;)
Nov 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Oven will not heat up, I can not hear any gas or smell any when attempting to light the oven
If the pilot is lit in the oven and does not light, the thermocouple on the gas valve is bad. The entire gas valve must be replaced.
May 19, 2009 | Tappan TGF657 Gas Kitchen Range
GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana ARGS7650SS Gas Kitchen Range Logo
231 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
