Question about Brother MFC-7220 All-In-One Laser Printer
WHEN I scan a document there is a line that comes out on the scanned item.
CLean the scanner. If it's a CIS scanner, replace the scanner chip.
Posted on Nov 09, 2010
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
How do I dlete scanned items
The scanned items should be stored somewhere on your computer as an image file(JPG, TIF, BMP, or PDF). Typically, when you scan a document you decide where to save the document. Simply browse to where the scanned documents are, right-click on one of the files then click Delete. This should delete the scanned document.
Mar 12, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Lines in scanned documents
The lamp of the scanner is the problem.
The problem could be as simple as the scanning mechanism which sweeps across the sheet being dirty...
else you will have to send it for repairs.
Jul 23, 2010 | HP PSC 2175 All-In-One InkJet Printer
Wont scan some checks and wont scan money orders
The software for your device has special security features programmed in that will recognize commonly counterfeited items.
This software will prevent unauthorized scanning of security documents like cashier's checks, money orders, United States currency, etc.
There is no way to remove this feature from your scanner's software. However, some software allows for very low resolution (100 DPI or less) scans of these documents.
You'll just have to experiment and see if you can scan these documents with your scanner at these lower resolutions.
Feb 04, 2010 | Vision Panini My X 60 Check Scanner
Trying to scan and then attach as document an 8.5 x 11 paper
Usually there will be a dashed line that is around the image. Sometimes it will just surround a darker portion of an image, such as the text portion on a white piece of paper. This is common. Use the mouse and aim it at the dashed line and "pull" the lines to the edges of your document, then press accept. This should fix your problem.
Jun 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
When scanning several pages of a document some pages scan fine, some you'll hear a draggin noise and there are smudge lines thru the document (putting thru feeder). Other times when you place 1 copy to be...
Well, if both feeder and pattern glass also having line on print, suspect hardwares problem...
U can check below items:
1. drum
2. laser unit
3. fuser unit
Mar 03, 2009 | Office Equipment & Supplies
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Oct 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanning Problems
I need some more information are the lines horizontal or vertical? Does it print fine from the computer? Does this problem only happen when you scan an item in and then print it or copying an item then print it? Also when you get this output do you have some of the text and lines or just lines?
Jan 08, 2008 | HP LaserJet 3050 All-In-One Printer
Brother MFC-7220 All-In-One Laser Printer Logo
52 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
