Question about GE GSH25JFR Side by Side Refrigerator
The fan is turns on but it doesnt get cold - GE GSH25JFR Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 09, 2010
Cooling fans on my 1998 Plymouth Voyager quit working. I replaced the fans and relay and they still dont work even when I turn on the a/c.
is it cold where your at or warm if its cold they wont come on because the temp out side keeps it cool enough but if its warm and still doesnt work sounds like wireing issue somewhere
Mar 17, 2013 | 1998 Plymouth Voyager
Refer door left open overnite. can hear it running but fridge and freezer are not cold.and it has run all day. What can I do? .
the fan that blows air from freezer to fridge is probably frozen with ice from all the moist air when door was left open turn off unit and let defrost will see screws where fan is located to help fan defrost us hair drier to free fan when free enough to turn freely turn on unit and push door switches or close door and listen for fan to go on if goes on turn off unit and and continue to defrost till fan and duct [airway ]is clear of ice than turn on and let run -if fan doesnt go on have tested may have burnt out from trying to run while frozen up repair or replace fan and recheck unit good luck
Jun 27, 2011 | Kenmore 94499 Refrigerator
My LG LWHD1200FR air conditioner turns on, but the fan doesn't spin and no cold air comes out. What's the problem? How do I fix this?
Which fan doesnt spin the inside fan or outside fan? If its the outside fan try replacing the dual capacitor for the fan and the compressor. First take the fan blade and see if it spins freely if you spin it and it stops immedietly the fan bearings are bad. If it spins freely replace dual capacitor. If trhis helps please rate me and do a testimonial.
May 31, 2011 | Heating & Cooling
Hi newish oven,seems when all the ovens are off the fan is blowing cold air, any ideas?
cold air from the fan forced element area in the oven? or from the air vent just above the door? if its from the air vent then this is normal if your oven senses the outside cabinet is getting to hot it will bring on the fan and if its still to hot after u turn it off the fan will continue as its circuit doesnt run through the control knobbs meaning it wont turn off with the oven its controlled via a overload thermostat so the fan will remain on til it gets within its acceptable temp range and the thermostat will cut power to the fan, if it remains on for hours and hours or even days you will be looking at a new thermostat (cheap as dirt like only a few bucks) or worst case a controller
Apr 02, 2011 | Stoves 600SiDOm Gas Kitchen Range
So my split fridge and freezer broke. the freezer works fine but the fridge doesnt get cold enough, even if i turn the knob to 7 (the highest).
first clean and remove dust and debris from under unit and make sure fan is working properly--next check the fan in freezer section for icing ,damage ,blockage ,or failure repair or replace as necessary the fan supplies the fridge with cold air from freezer
Nov 26, 2009 | Kenmore Refrigerators
Radiator fan does not come on. what is the location of the relay switch
The radiator fan relay is located in the underhood fuse relay center. The fan is comanded on by the engine control module. As the temperature reaches 220 degrees it turns the fan on. I hope this helps. If you need further help let me know as great feedback is very important to me.
Thank You,
Roy
Aug 23, 2009 | 1991 Chevrolet Beretta
My ac fan will not kick in....
replace fan motor the fan doesnt change speeds unless done by u
Jun 20, 2009 | Heating & Cooling
GE GSH25JFR Side by Side Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
