Question about Canon Office Equipment & Supplies
We have purchased a canon iR 1122 iF machine and will like to set it up to scan documents and forward them as an email, however our technicians are having problems can you direct me to the section of the manual or can you provide the information.
SOURCE: Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Posted on Jan 26, 2008
Logjam
  • 159 Answers
SOURCE: I want to scan then send instead of scanning whilst sending
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Posted on Feb 07, 2008
SOURCE: Users manual for the Canon ir c3220
http://www.service.canon.com.au/manuals/ufrv130.pdf Give this a go mate.
Posted on Sep 10, 2008
leroyal
  • 2120 Answers
SOURCE: faxing a high volume of responses on Brother MFC-8220
Hi Gina,
It sounds like the MEMORY function is not set to ON.
Is there a memory button on the control panel?
Posted on Oct 16, 2008
SOURCE: Canon MP500 keeps cropping scanned docs
i was having the exact same problem -- very annoying! just go to the following link and follow the instructions. VERY quick and easy!!!..... http://support-au.canon.com.au/contents/AU/EN/8000507501.html
Posted on Feb 10, 2009
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
Jun 12, 2012 | Office Equipment & Supplies
Steps for scanning and emailing a document using IR C4080
Scan to a folder and use barcode sheets with PixEdit will do it
Jun 15, 2009 | Canon imageRUNNER iR C4080 Color Copier
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
I have a Canon ir 3045 copier, when I try to send the scanned copy directly to a file, the file doesnot save to the destination network folder. When I looked at the scanner send logs i saw status as NG...
I have a Canon ir 3045 copier. I had sucessfully scanned two documents but the third scanned document (107 pages) was not emailed to me. When I click on press details, the job type reads #801. how do i retrieve the document?
Apr 24, 2009 | Office Equipment & Supplies
Scanning from a canon 3220
Yes, the type of scanning mentioned by the previous answer is called 'pull scanning' and you will have limited functionality. You have to load the document on the copier, turn on the scanner (nobody can use the machine now) return to your desk which I hope is not far from the copier because the doc stays there until you 'insert picture from scanner' then the machine scans the document and you run back to the copier to get it before someone throws it in the trash! It's a free system but limited. To have a fully functioning 'push scanner' where you send a doc as you stand at the copier to either a file on your computer, server or an email address you would need a universal send kit installed. If your machine has one you'l see the option tab called 'SEND' along the top of your screen. If you have this you're in luck. All you need is to enter the necessary network and email settings which can be done by any half decent network administrator vis the 'system settings' area from the addtional functions screen (accessed by pressing the head key with a star in it). Once this is set up merely select the 'SEND' tab and insert your document. In the top right hand corner will be a drop down menu reading either 'FILE' 'EMAIL' or 'FTP' If you want to send it to a shared folder on your network (anywhere) you select the 'FILE' option and then use the drop down menu in the centre of the screen to search the network for your shared folder. Select it and then press ok then the start key - IT'S GONE - IF YOU'RE LUCKY. To send to email you just select the 'EMAIL' option and enter the email address of the recipient and ok then start and you're in business provided that all the network and email settings are correctly entered and permissions for network access is set up. The machine needs a email account registered for it as well. I'm tired now - good luck.
Feb 17, 2009 | Canon imageRUNNER C3220 Color Copier
Canon IR C3100N - scanning and emailing - attachment is blank
So I take it that you are sharing email accounts with your photocopier otherwise you would not be trying to look at what you've sent? You will not be able to see the doc because it has sent it straight through your server and only using your account for access. There's no problem if the reciever can read the doc. I hope I've helped.
Canon Copier Service Manuals
Sep 17, 2008 | Canon imageRunner C3100 Copier
Canon ir 3570
Can anyone pls let me know the procedure to scan a document using Canon IR3570?
Mar 28, 2008 | Canon ImageRUNNER 3570 Copier/Printer
85 people viewed this question
old marine
old marine
