Vista won't connect to my printer wireless.
When i try and connect my printer wireless from my laptop it gives me a message "Windows cannot connect to the printer. Access is denied." How can I fix this problem?
  • 130 Answers
Try using the administrator section of your computer to try to get it setup, if that doesn't work you need to see if you can get updated drivers from the vista microsoft site, do drivers update, and you shpould be fine/
Posted on Jun 16, 2008
Connect another laptop to my wireless kodak printer but it won't recognise the printer
check the website of your printer such as if its a Lexmark go to and see if the model number is compatable with the Vista programming. A lot of printers do not operate with Vista. I have three printers that only operate with XP and Windows 7
Sep 01, 2012 | Kodak ESP 9 All-In-One InkJet Printer
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
Can't get epson Stylus nx400 to print from wireless laptops. printer connected to desktop with windows xp pro. both laptops use windows vista home premium.
As your printer is not wireless itself you need to shared the printer. To enable this goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps,
Feb 20, 2010 | Epson Stylus NX400 InkJet Printer
Cannot connect to wireless network with Vista
I don not think there is a problem with your laptop. It connects to your network when you use the Ethernet cable, because the wired network is yours. As to the 4 networks to which you are trying to connect with the wireless, they must be secured as they should be. If you want to access them (and why would you since you have your own Internet connection), you will have to ask authorization from the networks owners (your neighbors). If they agree, they will provide you with all the information you require to log on and share their bandwidth.
Dec 28, 2009 | Microsoft Windows Vista Home Premium with...
Can't connect Xp laptop to 64Bit Vista PC to be able to print across wireless network
yes easy to fix, just share your print driver give it a share name like canonmp780 on the pc it is connected to
then get on your laptop asuming its on your wireless network and in the start bar run this command. \\ your computer name one printer is connected to \ canonmp780.
so if your computer name is windows and your printer name is canonmp780 the run command will be: \\windows\canonmp780 hope this helps and really easiest way to connect to it.
Canon tech
Apr 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wireless problems with windows vista
You just need to remove the preferred networks on your vista, follow this.
Right click the wireless icon>network and sharing center>manage wireless network>remove all preferred OK.
Then connect again to your network that should solve it.
Jun 13, 2008 | Linksys Wireless-G Broadband Router
Sharing printer
May your printer doesn't fit to your operating system because Windows Vista is one of the complicated OS and hard to find installer or software to fit it in. Try to Replace your operating system that same as your brother have. maybe it can fix your problem!
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Connecting Toshiba laptop using windows vista to C7180
Hi there i know that HP are updating a lot of the drivers at the moment you could try the following websites (Free download) (Small charge)
I hope one of those helps but also try the XP driver as may vista might work on XP driver technology.
Thanks J
Jan 19, 2008 | HP Photosmart C7180 All-In-One InkJet...
Built in wireless not workong
vista?? or XP?? ensure that the wireless adapter is turned "ON"
Dec 28, 2007 | Compaq NX6110 TFT XGA Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
