Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - Black-on-Black
MODEL - SF362LXSBO USED THE SELF CLEANING OVEN,
MODEL - SF362LXSBO USED THE SELF CLEANING OVEN, now it won't ingnite. ALL I need is a part number for the control that lights the oven.
SOURCE: Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Posted on Aug 25, 2007
SOURCE: Estate Range #TE5400PXHQ0
MY SELFCLEANING WHIRLPOOL OVEN CLEANED ABOUT 30 MINUTES AND THEN STOPPED AND WENT INTO E2 AND F1. THE DOOR IS LOCKED AND WON'T OPEN. WE HAVE TRIED EVERY THING THE BOOK SAID AND NOTHING HELPS. DO YOU HAVE AN ANSWER?
Posted on Dec 20, 2007
SOURCE: Beaumark oven self cleaning
I have a bEaumark self cleaning oven and the inner glass is broken
Posted on Feb 17, 2008
SOURCE: changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Posted on Nov 06, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
Looking for schematics for Tappan Self Cleaning Oven 1989 sold by Montgomery Wards
Mike,
I need parts for my Tappan 1989 Self Cleaning oven and I can't read the model number anymore. What is your model number?
moparlou@gmail.com
Jan 15, 2011 | Microwave Ovens
Used self-clean mode..oven door wont open..tried fault code still won;t open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | Amana Kitchen Ranges
I am havine a problem getting the self cleaning working on my O'keefe & Merritt electric oven. I don't know the model, but I do know that it was purchased in 1978. I've used the self cleaning setting...
Keefe Merritt 12 6267 Manual Book
O & M was merged with what has become Frigidaire/Electrolux Home Products.
You can get parts from them.
The serial number for a built in wall oven from that era would be something like this : 11-6361-30/123
Electrolux's parts number is 800 599 7569. (Phone number)
If the oven needs replacing, Sears, Magic Chef, and Whirlpool offer something in this size range. (You need to measure the dimensions.)
You may need to "google" "O'Keefe & Merritt electric oven repair" plus your location. Electrolux's service department might provide a contact.
Nov 24, 2017 | Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Need directions for fridaigre self cleaning oven
i cannot find the model number on my frigidaire self cleaning stove.i need to know how the self cleaning works.i bought the stove used
Nov 26, 2008 | Frigidaire FEF352 Electric Kitchen Range
Whirlpool 30" Self-Cleaning Freestanding Gas Range - Black-on-Black Logo
47 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
