Question about Maxtor One Touch II (EO1E200) 200 GB Hard Drive
After 4 years of great performance, its disappear from the descktop, its there in the system and work, but its disappear from (My Computer). and I can't get any of the information inside, what can I do
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 09, 2010
I forget my blacberry id nd i want to change
You must have Blackberry Descktop Software installed on PC first
1 step: do backup data from your phone using Descktop Software
2 step: full wipe device from security options\wipe data
3 step(last): restore data using Descktop software
Oct 07, 2013 | RIM BlackBerry Curve 8520 Smartphone
Camera disappeared from my laptop
go to control panel use the utility system restore , put the last date that you know was working Good, and ready .
God bless you
Jul 22, 2013 | Sony VAIO Computers & Internet
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
I was in the add/remove programs thing, i think i accidentally removed my sound, cause the whole thing on the bottom bar disappeared, i went to control panel and tried to work it again, but it went all...
You acn do a system restore
Go to start >all programs>accesories>system tools > System restore .
Then select Restore my computer to an earlier time . then select a dark Colourdate and perform a system restore .
It will work .
But before doing this take a backup of imporatant documents
Jan 28, 2011 | Audio Players & Recorders
What are the step in solving computer hardware problems ?
I have a best solution to solve computer problems that can solve 70% problem of your system. I am talking about registry easy utility. A Registry easy program is a great ornament for all computer owners, since it helps to keep a computer in perfect working order. It is great for cleaning out the system registry to help the computer run smoothly, and is even great for fixing errors and preventing system registry errors from occurrence in the future. By performing registry easy program on a usual basis, you can make bigger life of your computer and keep it running smooth. I am giving you a link where you can download this software:
http://www.download-registry-cleaners.com/registryeasy/
Jul 05, 2010 | Computers & Internet
My desktop keeps disappearing
Hi!
Remove unnecessary programs installed on your computer. This will help you save space and then more room for special processes for system performance.
Next, I advise you to run a full computer scan. This will help eliminate viruses or spywares on your PC and I think which is also the culprit to your Desktop suddenly dissapearing. Viruses are nasty and they will do everything to bug your computer down.
Sep 10, 2009 | Computers & Internet
Printer disappears !
hi there are 2 types of wireless installation 1 is infrastructure and the other one is Adhoc in Infrastructure the computer and the printer are connected through a router this is a permanent sort of connection and remains even if the computer is shut down
but the Adhoc connection is a short duration connection in which the computer and the printer are directly connected and the connection is lost as soon as the printer or the computer is turned off
so its always recommended to connect teh printer using the infrastructure mode so that you do not face any problem
Apr 16, 2009 | HP Photosmart 3210 Printer
It is downgrade to usb 1.0, why?
can you please provide the model number of the usb hub?
and it could be that in the system bios, all ports have been set to 1.0 standard.
you can access the bios by hitting F2 or the del when the computer just starts up.
Feb 13, 2009 | Logitech Wingman 4-port USB HUB - Powered
Printer disappeared from computer page
I would recommend you to completely uninstall your printer from the system using the HP uninstall utility on for the printer & then perform a clean reinstallation of the printer software...
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Open Questions:
Maxtor One Touch II (EO1E200) 200 GB Hard Drive Logo
52 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
